V8 Renegade Kit, Hose connections? |
pete |
Oct 4 2012, 01:06 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
bulitt |
Oct 4 2012, 01:41 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I'm using an electric pump, but maybe this top pic will help.
bulitt |
Oct 4 2012, 01:42 PM
re-post
Bruce Hinds |
Oct 4 2012, 05:29 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I'm using an electric pump, but maybe this top pic will help. Hey Bulitt, Tell me about the electric pump, just wondering which one and how it does in everyday driving. Do I need a bigger alternator? In answer to the pump hose set up, it doesn't matter. What does matter is the arch in the hoses, it can cause air pockets if there's too much arch in the hoses. Also, mine is opposite the one in the picture. I put the alternator on the circut board side and the water pump on the driver's side since thats the side ther return line from the radiator is on. |
bulitt |
Oct 4 2012, 06:04 PM
Apologize for a quick hi-jack.
Bruce- I am using a Dedenbear WP3. 20 gals /minute. Only uses 3amps. It feeds the Dedenbear water manifold with one hose. The manifold is cast to distribute flow equally. The pump can bolt on to either end of the manifold. This allows the use of the stock fuel pump! Only have used this on the test stand, and it ran for an hour without overheating. Finishing rust repairs so never been on the road with it yet. Guy (914GT) turned me onto this setup and he has been using it since 2004? without issues. Other's have used the Meziere pump with dual outlet hoses (914SBC, for one.). It's small, quiet, and supposed to operate for @3000hrs. Replacement motors cost @98$ Pump was @ 270$, manifold @105$ It's a clean set-up and you may want to approach Guy with additional questions. You can see it hiding under the fuel pump. Just welded on an angle bracket and bolted it on with two rubber isolators. |
Bruce Hinds |
Oct 4 2012, 09:45 PM
OOPs, yes, sorry for the hi-jack....
The answer to the question if you missed it was: It doesn't matter. What does matter is the arch in the hoses, it can cause air pockets if there's too much arch in the hoses. Also, mine is opposite the one in the picture. I put the alternator on the circut board side and the water pump on the driver's side since thats the side ther return line from the radiator is on. |
Mike Bellis |
Oct 4 2012, 09:49 PM
Here's mine... Right before I sold it...
computers4kids |
Oct 4 2012, 10:30 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
my setup
Attached image(s) |
pete |
Oct 5 2012, 08:46 AM
Mike Bellis |
Oct 5 2012, 03:28 PM
Great! Thanks for the pics. However, after looking at them now I'm curious about something else. I bought this engine with the 914 engine mounting bracket. Why are the mounting points shorter on mine? See pic. Home brew bracket maybe. You might need some hardened washers above to clear the mounting console. Each car is slightly different. I need 3/8" to clear mine. Install just the engine bracket and see if it works. If not, add a washer, or another... |
Mike Bellis |
Oct 5 2012, 03:30 PM
Pics of my rotary engine bracket. Much less on top than my V8 bracket. I welded washers in place for this one...
Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 05:33 PM |
