Driver side mirror drill template?, Looking for some help here fellas |
jersey914 |
Oct 6 2012, 10:21 PM
Member Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States |
The PO filled in the mirror holes with "weld" and now the are unusable because they are full of weld material. I figured I would drill trough the weld material but that has proved impossible because of the lack of space and the fact that I Cant see well up in there. It looks like my best option is to drill from the outside and try to get as close the the right location as possible and then put some new lock nuts on the end of the threads from inside the door.
Has anybody created a good template for the OEM mirrors so that I can drill from the outside and be done this debacle? I want the mirrors mounted as close to spec as possible. Please advise!! rob (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Oct 7 2012, 12:22 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
If you can use a center punch on the inside and make a dimple on the outside you will have a target to drill on. Find the nuts inside the door. (If they are still there). Place the center punch as close to the center of the nut as you can and tap the punch lightly with a hammer. It will give you a small mark where you can then center punch from the outside and drill a reasonably accurate hole. Start with a small drill diameter.
jersey914 |
Oct 7 2012, 07:08 AM
If you can use a center punch on the inside and make a dimple on the outside you will have a target to drill on. Find the nuts inside the door. (If they are still there). Place the center punch as close to the center of the nut as you can and tap the punch lightly with a hammer. It will give you a small mark where you can then center punch from the outside and drill a reasonably accurate hole. Start with a small drill diameter. Eliott, that was the first thing that I tried to do bit the P/O filled in the nut with so much weld material it is sticking out the nut. There is no way to use a hole punch from the inside. Even if I could use those holes, the thread on the nut is unusable. next??? |
t collins |
Oct 7 2012, 08:06 AM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Rob,
I took the following measurements from my 71 door. Sorry had to locate off the rear of the door due to vent rubber in the way. Hope this helps. Tom |
jersey914 |
Oct 7 2012, 08:09 AM
t collins |
Oct 7 2012, 08:12 AM
Harpo |
Oct 7 2012, 08:28 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
jersey914 |
Oct 7 2012, 08:51 AM
So Tom, if i am reading this correctly, we have 27.5" to the center of the front hole and 1.18" back to the center of the rear hole. The holes sit out .620 out from the molding (not the inside edge of door)?? Please confirm! (IMG:style_emoticons/default/biggrin.gif) |
Harpo |
Oct 7 2012, 08:54 AM
Are the dimensions the same Right & left?
DAvid |
t collins |
Oct 7 2012, 09:02 AM
No, its 27.5" from the rear of the door to the rear hole and then another 1.180" to the front hole. The holes are .620 off the inside door edge.......a measurement from the molding would not be very accurate.
Lo-Fi Version | Time is now: 11th June 2024 - 08:00 AM |
