Caliper sticking, Pads hanging up on 1 front |
jim_hoyland |
Oct 31 2004, 11:25 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Yesterday, my front left modified BMW 320i caliper began squeeking when pedal is off and going slow. Hit the pedal a couple of times and it went away. Got home and checked to see if caliper was hot. Pretty hot.
Is there a quick fix to this; or does the caliper need to be removed and sent in ? |
Rusty |
Oct 31 2004, 06:32 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Had this happen two weeks ago.
Jack the car up... pull the wheel. Pull A pad out... it'll take some effort. Using some wood in place of the pad, stomp on the pedal. Pry the piston back. Repeat. Then repeat process with other pad. Hopefully, you can break the stuck piston loose. If not, you can probably rebuild the caliper yourself. -Rusty (IMG:style_emoticons/default/smoke.gif) |
jim_hoyland |
Oct 31 2004, 07:15 PM
Thanks for the headsup; Do you lubicate anything after prying ?
What causes the sticking ? I'll try it tomorrow after work |
Rusty |
Oct 31 2004, 07:22 PM
Nope. No lubrication.
Rust in the cylinder bore usually causes the cylinders to stick. You can usually polish it out with some 400+ grit sandpaper when you do the rebuild. If you can R&R a caliper, you CAN rebuild the caliper. (IMG:style_emoticons/default/smile.gif) Recommend you do both both calipers on the same axle. Invest in a couple cans of brake cleaner to help clean things up. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Cap'n Krusty |
Oct 31 2004, 08:08 PM
Before you do all that, hit the pedal hard, check the drag after it's released, then hit it again, release it, and crack the bleeder. If the drag is released, replace the front hoses with nice new OE rubber ones. The Cap'n
jim_hoyland |
Nov 1 2004, 01:55 PM
Do you think there is a defect in the hose ? Interestinly, the squeek ( rubbing againgt the rotor) alway returns when I brake to make a 90 degree turn. Would that make sense ?...
Thanks. |
mike_the_man |
Nov 1 2004, 02:09 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Could be kinking the hose when turning. If you don't know the condition of the hoses, it wouldn't hurt to replace them. They're not that expensive, and the front ones are easy to replace. The back hoses, on the other hand, not quite so easy.
jim_hoyland |
Nov 1 2004, 03:12 PM
Hmm.. thank you.
Lo-Fi Version | Time is now: 8th June 2024 - 05:25 AM |
