Something Amazing Happened today, I cleaned the garage - 914 fits! |
qa1142 |
Oct 31 2004, 06:23 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Well, as winter approachs I needed space to put up and work on my teener. I emptied my portable garage that has been my 914's home all summer. Then cleaned the attached garage, put all the bikes and stuff into the portable, and parked my 914 INSIDE.
I have not had a car in it in nearly 10 years! Insurance is up on Nov 14th and up on jack stands it will go till ~ April. Winter projects: Drop and rebuild engine Clutch - if needed pull engine sound pad, paint engine compartment replace rear bushings Clean and repack CVs new rear struts and springs pull gas tank, install front swaybar new ball joints new front bushings Check tie rods Install rebuilt petal cluster and alum petal board touch up any under chassie rust with por 15 Pull rockers, fix one jack support, longs are good, touch up any rust there too, repaint longs Replace plastic fuel lines with SS through tunnel Install OEM center console w guages That should get me to March. I'll post pictures as I go. |
jim912928 |
Oct 31 2004, 06:27 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Nice winter list! If you do the front bushings with the basic weltmeister bushings...you need to cut grooves on the inside so you can pack some grease in there..otherwise it will squeek squeek squeek...don't ask me how I know!
Lo-Fi Version | Time is now: 8th June 2024 - 11:03 AM |
