CSOB Wheel Center Capsi |
bandjoey |
Oct 23 2012, 11:44 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
2.5" plastic pipe end cap
Cut off 18mm Thin down 1-2mm Paint Fits rear perfectly Will have to thin a little more on fronts. Will do those next weekend. $2.25. Attached image(s) |
76-914 |
Oct 23 2012, 12:29 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Just to clarify. They don't make PVC or ABS in 2 1/2". I'll bet your referring to 2". 2" pipe measures 2 1/2" od
bandjoey |
Oct 23 2012, 01:27 PM
Yep. Box said 2.5
Mike Bellis |
Oct 23 2012, 01:46 PM
76-914 |
Oct 23 2012, 03:35 PM
They do make (in plumbing) 2 1/2" PVC for pressure pipe (type 1), but not in the DWV or type ll. Nor is it available in ABS, anywhere. 2 1/2" is seldom used because it is cheaper to run 3" and reduce when/where necessary. That sure looks like a "2" stamped on top of that fitting. But then again I'm sitting in the dentists chair using the iphone and probably slightly modified. (IMG:style_emoticons/default/biggrin.gif)
bandjoey |
Oct 23 2012, 06:49 PM
Cheap and ur right. 2" pipe for the plumber and something bigger on the outside. Didn't take much off and it fit perfectly.
Now should I get the eBay plastic center cap Porsche stick on decals ?? Or s that too much pimp?? (IMG:style_emoticons/default/drooley.gif) |
69telecaster |
Oct 24 2012, 10:51 AM
Member Group: Members Posts: 101 Joined: 4-April 10 From: White Cloud, MI Member No.: 11,558 Region Association: None |
Cheap and ur right. 2" pipe for the plumber and something bigger on the outside. Didn't take much off and it fit perfectly. Now should I get the eBay plastic center cap Porsche stick on decals ?? Or s that too much pimp?? (IMG:style_emoticons/default/drooley.gif) What holds them in? |
bandjoey |
Oct 24 2012, 04:03 PM
Squeeze fit just like the originals. They're about 1-2 mm snug fit with a mallet.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:49 AM |
