messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
It's too bad our care thrive only on Dino oil. Many threads and current research shows we will chew up the motor on new oil.
Yuum |
drgchapman |
Current Stable ![]() ![]() ![]() Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest ![]() |
It's too bad our care thrive only on Dino oil. Many threads and current research shows we will chew up the motor on new oil. Yuum It's actually the addition of Zinc to the older oils, the zinc cushions the cam-rocker interface. New oils don't need the zinc as the cam-rocker materials/construction is different on newer engines. |
messix |
notice that porsche spec's 20,000 mile oil service intervals!!!!
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
From a chemical standpoint I think they are right on target. Many of us are interested in the wash-out aspect though. The oil could be perfectly OK as a lubricant, but if it is loaded with particles with abrasive qualities, it is best to change them out. But we really have little data about whether or not those particles are there. If they are just carbon, they probably aren't very abrasive. Then you go down the list through aluminum dust and bearing powder - both soft metals, but hmm. Then steel, but that isn't falling off by itself. Then really hard materials such as stone dust and sand. So, the jury is out I would say. I remember reading about a Model T crossing the country with oil as clean as a whistle. Never changed the oil once! They added a quart every hundred miles or so to keep up with the leaks.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,120 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Royal Purple has acceptable zinc content and is synthetic... 20W50 and you're good to go... Plus it's a cool purple color. (IMG:style_emoticons/default/biggrin.gif)
Now to add to the discussion, We for the most part use our cars differently than most of the people considered in that article. Not many of us daily drive these cars. At that point you have to consider time and not miles as the benchmark. I use spring and fall as change points. A friend of mine, who is a 914 guy who lurks here and has a high performance shop that works on BMW, Porsche, Audi, etc. differed with the owners manual on my wife's Audi A4 2T. I think her manual said 10K miles but Ron said he uses a benchmark of 1000 miles per quart capacity. That cut the factory interval in half I think. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
It's too bad our care thrive only on Dino oil. Many threads and current research shows we will chew up the motor on new oil. Yuum I've been using synthetic oil (Mobil 1) for the past 25,000 miles with no problems. Of course the ceramic lifters help a bit I think. (IMG:style_emoticons/default/laugh.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,021 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
and I also use royal purple
be careful though... there are 2 different formulas of royal purple now (well 3 actually with the race only oil) their standard RP doesn't have the zinc you need the HPS version.... or what ever its called.... the one with zinc and it puts it right onto the label. |
Lo-Fi Version | Time is now: 31st July 2025 - 09:52 PM |
