SLKWrx |
Member ![]() ![]() Group: Members Posts: 328 Joined: 28-September 04 From: Mickleton, NJ Member No.: 2,845 Region Association: North East States ![]() ![]() |
I have recently found a puddle of oil on the drivers side engine shelf, nothing on the passenger side. This is the second time I have found this. The first happened after a long drive, this time was after a 30 min ride. The only change has been a valve adjustment. But I don't understand how a valve adjustment would cause oil to pool on top of the shelf. Any ideas? (IMG:style_emoticons/default/blink.gif)
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
I'd check the valve cover gasket.
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
I have recently found a puddle of oil on the drivers side engine shelf, nothing on the passenger side. This is the second time I have found this. The first happened after a long drive, this time was after a 30 min ride. The only change has been a valve adjustment. But I don't understand how a valve adjustment would cause oil to pool on top of the shelf. Any ideas? (IMG:style_emoticons/default/blink.gif) Does your heads have the oil breather tubes coming out next to the air intake tubes? Most D-Jet heads had them, not sure yours do (i only see that you have a 2056) If so, one of them might be leaking blowby and oil on that one side. I hope this helps. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,282 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Valve cover gasket, head breather connection or hose, thermostat wheel through bolt. Those are 3 things i can think of that are in that area. (IMG:style_emoticons/default/idea.gif) |
SLKWrx |
I'll check all of those things. I thought it might be the valve cover gasket, but how does it get to the top of the engine shelf? Thanks guys, I appreciate the advice.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,021 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
when we used to blow valve cover gaskets on the old race car
it was always oil on the top of the shelf I think it goes below too... but drips away the oil on top was always the indicator. |
Lo-Fi Version | Time is now: 31st July 2025 - 02:27 PM |
