Full Version: Oil on driver side engine shelf?
SLKWrx
I have recently found a puddle of oil on the drivers side engine shelf, nothing on the passenger side. This is the second time I have found this. The first happened after a long drive, this time was after a 30 min ride. The only change has been a valve adjustment. But I don't understand how a valve adjustment would cause oil to pool on top of the shelf. Any ideas? blink.gif
dlee6204
I'd check the valve cover gasket.
Cupomeat
QUOTE(SLKWrx @ Oct 24 2012, 06:29 PM) *
Does your heads have the oil breather tubes coming out next to the air intake tubes? Most D-Jet heads had them, not sure yours do (i only see that you have a 2056)
If so, one of them might be leaking blowby and oil on that one side.
I hope this helps.
Valve cover gasket, head breather connection or hose, thermostat wheel through bolt.
Those are 3 things i can think of that are in that area.
SLKWrx
I'll check all of those things. I thought it might be the valve cover gasket, but how does it get to the top of the engine shelf? Thanks guys, I appreciate the advice.
brant
when we used to blow valve cover gaskets on the old race car
it was always oil on the top of the shelf
I think it goes below too... but drips away
the oil on top was always the indicator.
