> Oil on driver side engine shelf?, No clue when or how
SLKWrx
post Oct 24 2012, 04:29 PM
I have recently found a puddle of oil on the drivers side engine shelf, nothing on the passenger side. This is the second time I have found this. The first happened after a long drive, this time was after a 30 min ride. The only change has been a valve adjustment. But I don't understand how a valve adjustment would cause oil to pool on top of the shelf. Any ideas? (IMG:style_emoticons/default/blink.gif)
dlee6204
post Oct 24 2012, 04:36 PM
Howdy
I'd check the valve cover gasket.
Cupomeat
missing my NY 914 in VA
QUOTE(SLKWrx @ Oct 24 2012, 06:29 PM) *
Does your heads have the oil breather tubes coming out next to the air intake tubes? Most D-Jet heads had them, not sure yours do (i only see that you have a 2056)
If so, one of them might be leaking blowby and oil on that one side.
I hope this helps.
post Oct 24 2012, 04:44 PM
Resident German
Valve cover gasket, head breather connection or hose, thermostat wheel through bolt.
Those are 3 things i can think of that are in that area.
SLKWrx
post Oct 24 2012, 05:10 PM
I'll check all of those things. I thought it might be the valve cover gasket, but how does it get to the top of the engine shelf? Thanks guys, I appreciate the advice.
brant
post Oct 24 2012, 05:52 PM
when we used to blow valve cover gaskets on the old race car
it was always oil on the top of the shelf
I think it goes below too... but drips away
the oil on top was always the indicator.
- Lo-Fi Version Time is now: 30th July 2025 - 07:14 PM
