engine removal, is there a thread? |
Ian Stott |
Oct 30 2012, 10:12 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Engine coming out, for cleanup and minor rust repair.Is there a do's and don'ts thread?
Ian Stott Moncton Canada |
StratPlayer |
Oct 30 2012, 10:20 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Ian Stott |
Oct 30 2012, 10:26 AM
Thank you, that's just what I was hoping to find. Things like this are what make this a great club! Ian Stott |
billh1963 |
Oct 30 2012, 10:33 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I used that article and it is very straightforward. i have pulled three engines and now i can drop one very quickly!
76-914 |
Oct 30 2012, 03:07 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Watch that the hose clamps on the fuel rails don't hang on the shelves.
stugray |
Oct 30 2012, 03:46 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Removing the engine with FI is much more difficult than carbs.
QUOTE Watch that the hose clamps on the fuel rails don't hang on the shelves. I found it is best to just remove the fuel rails before dropping, but is not required if you are careful and like to take risks. I bet that most fuel rail leaks are due to damage from removal of the engine.... Stu |
majkos |
Oct 30 2012, 03:52 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Removing the engine with FI is much more difficult than carbs. QUOTE Watch that the hose clamps on the fuel rails don't hang on the shelves. I found it is best to just remove the fuel rails before dropping, but is not required if you are careful and like to take risks. I bet that most fuel rail leaks are due to damage from removal of the engine.... Stu (IMG:style_emoticons/default/agree.gif) I often wondered about that. |
Rockaria |
Nov 1 2012, 09:57 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
When I dropped mine this past summer I found this table lift at Harbor Freight. Less than $200 bucks and it made the job really easy. The handle comes off. Lift into place. Use some wood blocks, drop. Going back in was even easier. Lifted right into place and holds it very steady.
http://www.harborfreight.com/500-lb-capaci...able-94822.html |
rwilner |
Nov 2 2012, 10:07 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Is there a do's and don'ts thread? I found McMark's article on this site to be more useful and straightforward than the pelican article. http://www.914world.com/specs/tech_engdrop1.php |
Lo-Fi Version | Time is now: 28th May 2024 - 11:16 PM |
