Harness bar VS Firewall, for harness installation. |
Andyrew |
May 14 2003, 08:17 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Harness bar VS Firewall, for harness installation..
Well I am now doing some contemplating, I am going to put some camlock black harnesses, one for the driver, and one for the passanger, in my car. Mainly because I just dont feel safe with the stock one's, and because I like the one's in my dads 951. My question, I have seen 914's at auto x's with harness's mounted to the car via harness bar, and via firewall. Is the firewall way safe? Is it a generally accepted idea? Also if I do go firewall, would I have to get rid of the backpad and put carpet in there? Or could I cut 2 holes per side in the backpad? Also Is using harnesses (I will be getting simpson camlocks hopefully) Illegal for the street? Thanks alot guys! |
ChrisReale |
May 14 2003, 08:50 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I have seen both, and for AX, I will probably just get the harness bar. Its easy. I think Firewall mounting is safe also, but do not use generic hardware store bolts, because they dont have the same strength to weight ratio, or something like that.
Qarl |
May 14 2003, 09:06 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
If you go the firewall route, mount them high up, underneath the rib, just below the window and the hinges. Drill your through-holes
Use the harness mounting plate (rectangular plate with a nut welded to it), and weld that all around the edges on the engine side of the firewall. For more strength, drill your holes, weld a larger rectangular plate on the wall first (to distribute the force), and then weld your mounting plates to that. If you go the firewall route, you probably want to leave your firewall bare, or carpet it. That's what I am doing. Here's a nice picture. (not my car). My Boxster has a carpeted rear firewall, so it should turn out somewhat similar in appearance. Attached image(s) |
Andyrew |
May 14 2003, 09:30 PM
Thanks both of you. Has anyone ever been in a accident with firewall mounted harnesses? Did the firewall hold up? Thanks!
Qarl |
May 14 2003, 10:12 PM
This setup is used in racing quite a bit and to my knowledge is quite acceptable to most of the sactioned racing bodies. It will hold.
Also, get the substrap (5-point harness). The substrap helps keep the two side straps (lap belts) in place around your pelivis so that as you go flying forward that they don't cinch up around your soft inner organs beneath your ribcage. I'm installing a Scroth Profi III 5-point camlock setup on both sides of my car. Regards, Karl Attached image(s) |
Andyrew |
May 14 2003, 10:54 PM
Yup, I am going to get 5 point harness's, and in black (dont want to give a cop any reason to pull me over, if its black, it looks closer to stock than red or blue one's)and camlock, at least the drivers side.
campbellcj |
May 14 2003, 10:55 PM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Most/all race sanctioning bodies require either a firewall/bulkhead mount or a rollcage mount; harness bars are typically frowned upon, presumably due to strength concerns.
The other issue with the harness bar setups is that -- depending who you believe -- the height/angle is too high. I always forget the exact specs, but you basically don't want to deviate to far from a 90deg angle in the belts. Also...a 5pt harness w/o a proper (slotted) race seat and roll bar/cage borders on something between unsafe, and a waste of time/money. Best to go the whole way, if you're gonna head down that road at all. |
Qarl |
May 14 2003, 10:56 PM
Yes. mine are actually black and yellow...
Substrap not shown... (although the seat does have a substrap hole). Regards, Karl Attached image(s) |
Qarl |
May 14 2003, 10:57 PM
They feel really fast (especially in the kitchen).
Attached image(s) |
EdwardBlume |
May 14 2003, 11:02 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I went through the firewall with all the necessary hardware supplied by Frey Racing.
They set me up with double bolts and thick large washers. Drilling the holes were very easy. While I like the carpet and wonder why I didn't think of it, I actually reinstalled the backpad with holes for straps to the eyebolts. I also have a welded in roll bar. I just cut holes in the backpad carefully (and removed some stuffing). I feed the straps through, loop the belt, and then get the pad in place. Even with a hybrid seat, the seat goes all the way back into the pad. Let me know if you want some picts. Good luck. |
Andyrew |
Chris, Im glad you brought that up, I am going to fiberglass a pair of stock seats.. should I put in holes for the shoulder straps? what about on the side, by your bunz.. Im going to find a seat that I like, and copy some of the dementions and make my "perfect" seat.. should be interesting!! Any ideas or hints? When Im done I'll have a local fabric shop put some padding in, and put vinal on it. This way I can retain my stock seat rails! Got the idea after I found out the stock seats are fiberglass, and looking at renegades seats did help...
Andyrew |
May 14 2003, 11:12 PM
cavwpguy, Did you buy harnesses that where roll bar mount and then use the stuff Fray Racing gave you to mount it to your firewall? Also why didnt you use the roll bar to mount the harnesses to? Was it because the roll bar wasnt in the correct position (way to high over head) or some other reason. Pictures would be great! The more Ideas I get, the better!!!! hehe, I love being young ideas come quick!
EdwardBlume |
May 14 2003, 11:19 PM
I bought the harness with the intention of using the eyebolts and drilling through the firewall.
The bar was welded in before I had the harness. The other trick was getting the backpad into the car after the bar went in. I was told it couldn't be done (it can-sort of). I'll pull some picts tomorrow. |
Andyrew |
May 14 2003, 11:36 PM
My backpad isnt perfect, the drivers side has a rip (I notice this is very common, as I see it in almost every daily driven 914 I have seen) but the rest is very good. I have 2 more backpads, that If I do a little sewing and glueing, I can make it look good. But it might save me some money just to carpet it. It would also be easyer to keep clean, and looking nice.
EdwardBlume |
May 14 2003, 11:39 PM
Here's a view from across the seat.
Attached thumbnail(s) |
EdwardBlume |
May 14 2003, 11:40 PM
Here's from the drivers side
EdwardBlume |
May 14 2003, 11:42 PM
Heres from behind
EdwardBlume |
May 14 2003, 11:43 PM
Also, if you have three backpads, you can take them apart in 3 sections and put together your best parts.
Good luck! |
914werke |
May 15 2003, 10:52 AM
"I got blisters on me fingers" Group: Members Posts: 10,149 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Rob is that Renegade Seat the Touring ver?
EdwardBlume |
May 15 2003, 07:28 PM
Yep. I like it.
Lo-Fi Version | Time is now: 13th June 2024 - 06:27 AM |
