carb question - idle air mixture screw |
Jerry75914 |
Nov 5 2012, 07:16 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
Hi all! I have a fairly new 2270 with dual Weber 44idfs ( all hail McMark for making my 914 so much more fun!). Recently it started randomly idling like crap, running fine, running like crap...would change from stoplight to stoplight.
I did some searches on clogged jets, and this morning I pulled my mains (fine), idles (mostly fine, only one slightly blocked), and the idle air mixture screws ( two were dirty on the ends, probably where my issue was. I blew carb cleaner into all the holes, and viola, running like a top. My question is whether all the idle air mixture screws should be turned out the same? I noted their positions before taking them out, and counted how many turns to seat them, then removed. three out of four were just about one full turn out, but one was only a half turn. Sound normal? Should I give the one screw another half turn out to be the same as the others? Appriciate any thoughts! |
Trekkor |
Nov 5 2012, 08:37 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
The problem was likely the clogged idles.
The screws are for fine tuning the air speed in each cylinder. Done with the synchronizing tool, linkage disconnected. KT |
Lo-Fi Version | Time is now: 28th May 2024 - 11:28 PM |
