is a flashback valve the same as a PCV, can I use something else |
freezing14 |
Nov 3 2004, 03:14 PM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
i am finally done with the engine wiring and I am now in the process of putting all new vacuum hose , i got new hose, nice color diagram, I have all the parts but the flash back , do you have a picture can you adapt something, what about the trottl body I got 2 different 1 that has a adjusting screw on the top the other one on the side , which one is right for a 1.7 72, the number of vaccum port are different too ??? any hints
a 914 almost ready to start |
SLITS |
Nov 3 2004, 03:44 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The answer is no - send me your address, I'll send you a "flashback" valve. End of story. Pics a little later of the TB.
Joe Bob |
Nov 3 2004, 03:48 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
QUOTE(SLITS @ Nov 3 2004, 01:44 PM) The answer is no - send me your address, I'll send you a "flashback" valve. End of story. Pics a little later of the TB. Make sure you wash it first...he uses it for an anti fart valve.... |
SLITS |
Nov 3 2004, 04:12 PM
(IMG:http://www.rccauto.com/ebay/tb.jpg)
This is a 1.7 installed on the plenum. Butterfly cam is up and screw can be seen. Pharting cleans it out so it works correctly! (IMG:style_emoticons/default/icon8.gif) |
freezing14 |
Nov 4 2004, 07:49 AM
thanks slits, i have e-mail you my address and thanks for the picture, 1 thiong I noticed is that the tb has a little flit tab to attached the spring, the difference between the two i have is that the other one does not have a tab the spring attache right where the throttle cable goes
thanks again (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:34 PM |
