Re-badging my car, want them to know a VW just passed them |
machina |
Nov 3 2004, 04:55 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Dr. Porsche designed them all anyway.
So I'm starting with the motor. Jake will be proud. Next is the motor lid and the rear reflector. Attached image(s) |
sanman |
Nov 3 2004, 05:00 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
I like the covers. where did you get them? do they make dif sizes
Aaron Cox |
Nov 3 2004, 05:01 PM
i have the same rainshields.
morphenspectra makes them. check the resources forum |
machina |
Nov 3 2004, 05:02 PM
contact nathan at: hjhl@worldnet.att.net
he had them on e-bay but I think he is a member here as well. |
Aaron Cox |
Nov 3 2004, 05:04 PM
are you running the CB top plate or just the f/g shields?
SLITS |
Nov 3 2004, 05:09 PM
How 'bout a sticker that says, "You've just been passed by a VW"?
seanery |
Nov 3 2004, 05:11 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
how 'bout one of these on it?
(IMG:http://www.914world.com/bbs2/uploads/post-11-1099514081.jpg) |
machina |
Nov 3 2004, 05:34 PM
QUOTE(acox914 @ Nov 3 2004, 07:04 PM) are you running the CB top plate or just the f/g shields? The hats are sitting on top of the CB aluminum plates. I don't think it would seal well enough without the plates. |
machina |
Nov 3 2004, 05:35 PM
QUOTE(seanery @ Nov 3 2004, 07:11 PM) how 'bout one of these on it? (IMG:http://www.914world.com/bbs2/uploads/post-11-1099514081.jpg) that's nice, How did you do that script? Is it a font or a graphic? |
seanery |
Nov 3 2004, 05:42 PM
graphic I made today. I can make these in vinyl
Aaron Cox |
Nov 3 2004, 05:48 PM
QUOTE(synthesisdv @ Nov 3 2004, 04:34 PM) QUOTE(acox914 @ Nov 3 2004, 07:04 PM) are you running the CB top plate or just the f/g shields? The hats are sitting on top of the CB aluminum plates. I don't think it would seal well enough without the plates. you bought longer studs? also, did you use any sort of rubber dampening material? |
machina |
Nov 3 2004, 05:49 PM
QUOTE(acox914 @ Nov 3 2004, 07:48 PM) QUOTE(synthesisdv @ Nov 3 2004, 04:34 PM) QUOTE(acox914 @ Nov 3 2004, 07:04 PM) are you running the CB top plate or just the f/g shields? The hats are sitting on top of the CB aluminum plates. I don't think it would seal well enough without the plates. you bought longer studs? Nope, they were just long enough. You can open the filter and unscrew the long stud a couple turns. Should have enough meat on them. |
Aaron Cox |
Nov 3 2004, 05:58 PM
QUOTE(synthesisdv @ Nov 3 2004, 04:49 PM) QUOTE(acox914 @ Nov 3 2004, 07:48 PM) QUOTE(synthesisdv @ Nov 3 2004, 04:34 PM) QUOTE(acox914 @ Nov 3 2004, 07:04 PM) are you running the CB top plate or just the f/g shields? The hats are sitting on top of the CB aluminum plates. I don't think it would seal well enough without the plates. you bought longer studs? Nope, they were just long enough. You can open the filter and unscrew the long stud a couple turns. Should have enough meat on them. whats the thread on them? m5? m4? looks like you ditched the wingnuts |
spare time toys |
Nov 3 2004, 09:16 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
QUOTE(seanery @ Nov 3 2004, 06:42 PM) graphic I made today. I can make these in vinyl Can you make them in a gray and sized to fit the long. covers? Im thinking behind the jack point. (IMG:style_emoticons/default/smile.gif) |
seanery |
Nov 3 2004, 10:22 PM
Larry,
I sure can, get me a measurement and I'll let you know how much $. I don't know if I'll be able to get an exact color match for your gray though. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:15 AM |
