Need Help Before I Screw Up!, Roll Bar Trim Molding Removal Help |
JawjaPorsche |
Dec 3 2012, 06:09 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
It makes a job much easier when you know what you are doing! I am going replace my sail vinyl and I need to remove the trim molding.
Looking the Roll Bar Trim Molding, there a phillips head screw at the top. (I think I can figure that out!) (IMG:style_emoticons/default/beerchug.gif) I found a picture of the Roll Bar Trim Molding. Looking at the picture there seems to be a channel at the bottom. Do you remove the screw at the top then slide the molding out at the bottom backwards toward the rear? Any help, needless to say, will be greatly appreciated! (IMG:style_emoticons/default/beer.gif) Attached image(s) |
dlee6204 |
Dec 3 2012, 06:16 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
There is a nut up under fender you need to loosen before you can "slide" the trim off. But otherwise you got the right idea.
Jeffs9146 |
Dec 3 2012, 06:31 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Eric_Shea |
Dec 3 2012, 06:36 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Small 8mm nut holds a clamp which pulls down the trim. Make sure you note which way the clamp is oriented for reinstallation. If you put it back wrong you will dent the very expensive trim.
PanelBilly |
Dec 3 2012, 07:43 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Be prepared for the nut to break off because its rusted from being in the elements of the wheelwell
JawjaPorsche |
Dec 3 2012, 07:55 PM
That is not what I want to hear!
(IMG:style_emoticons/default/huh.gif) Be prepared for the nut to break off because its rusted from being in the elements of the wheelwell |
euro911 |
Dec 4 2012, 12:37 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Clean any undercoating (or other foreign residue) from the stud and nut, then spray it with PB a day ahead of going to town on it (IMG:style_emoticons/default/idea.gif)
JawjaPorsche |
Dec 4 2012, 05:41 AM
Sounds like a good plan! (IMG:style_emoticons/default/beerchug.gif)
Clean any undercoating (or other foreign residue) from the stud and nut, then spray it with PB a day ahead of going to town on it (IMG:style_emoticons/default/idea.gif) |
JawjaPorsche |
Dec 4 2012, 08:56 AM
Cleaned with Simple Green and sprayed with PB. Doesn't look bad but only time will tell. Keeping fingers crossed!
[quote name='euro911' post='1778020' date='Dec 4 2012, 01:37 AM'] Clean any undercoating (or other foreign residue) from the stud and nut, then spray it with PB a day ahead of going to town on it (IMG:style_emoticons/default/idea.gif) [/quote] [/quote] Attached image(s) |
Eric_Shea |
Dec 4 2012, 09:20 AM
If it breaks you're done. No big deal. Just grab another one from Bruce or someone in the classifieds.
Lo-Fi Version | Time is now: 3rd June 2024 - 07:17 AM |
