MSD 6AL- should I install one? |
tornik550 |
Dec 7 2012, 08:53 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a 2258 that is setup for spirited weekend driving and also auto-x. The car runs great, very pleased with the power. I have a MSD 6al with tach adapter laying around. I didn't install it cause I heard it doesn't help much and I thought it would just complicate my setup. Is it worth while for me to install it?
Jeffs9146 |
Dec 7 2012, 09:56 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have a 2258 that is setup for spirited weekend driving and also auto-x. The car runs great, very pleased with the power. I have a MSD 6al with tach adapter laying around. I didn't install it cause I heard it doesn't help much and I thought it would just complicate my setup. Is it worth while for me to install it? I guess you asked the wrong question in the Classifieds section so I will tell you my feeling as it relates to my car! It works great on my 6! As for a 4, I will leave this to everyone else! |
ConeDodger |
Dec 7 2012, 10:04 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Works fine on a 4 as well.
I have two of them that I am not using if you want to buy one. PM if you do. |
Krieger |
Dec 7 2012, 11:48 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Why not? You have it. You can always remove it if you don't think its worthy.
jim_hoyland |
Dec 8 2012, 08:28 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I've run the MSD 6 for the past 5 years on my -4: I found it worked even better after installing the Mallory Unilite distributed. Engine runs cooler, doesn't,t ping on grades, starts faster, gets better gas mileage, and allows for better acceleration through a wider range of RPM.
One caution: set up your wiring so you can revert back to non-MSD in case of failure. Recently, I disconnected the MSD for a rewiring project; first thing I noticed was a drop in gas mileage.... (IMG:style_emoticons/default/smile.gif) |
michael7810 |
Dec 8 2012, 09:42 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
What spark plug gap are you 4-cyl guys running with MSD. The MSD directions say 0.050 but the local shop who help tune my car recommended to stick with the stock 0.028.
jim_hoyland |
Dec 8 2012, 11:10 AM
I used the stock gap, I think it depends on your engine and of course which coil you use. I used a Bosch blue coil and have a slightly modified L-Jet F I
Jeffs9146 |
Dec 8 2012, 11:12 AM
What spark plug gap are you 4-cyl guys running with MSD. The MSD directions say 0.050 but the local shop who help tune my car recommended to stick with the stock 0.028. I am running 0.045 on the 6! The instructions say to increase the gap by 0.005 and test untill you find the sweet spot! I am running a 6000 rpm rev-limiter for the street! |
worn |
Aug 5 2013, 07:46 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What spark plug gap are you 4-cyl guys running with MSD. The MSD directions say 0.050 but the local shop who help tune my car recommended to stick with the stock 0.028. Mine died in about 150 miles. Fortunately it was triggered by a Crane set up so I could easily change it over to directly trigger the spark. Explains the intermittent failure to run the engine in traffic (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:09 PM |
