| JeffBowlsby |
Dec 10 2012, 08:26 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,393 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I have seen this part referenced to this part number in a few locations...beware.
I know of another part thats the same story...its the small rubber bellows at the clutch cable by the trans pulley, the replacement parts is about 5 in. long...looks the same in photos, but it doan fit. Anyone have the replacement part that can post the photo? Attached thumbnail(s) Attached image(s)
| 914Sixer |
Dec 10 2012, 08:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,615 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Jeff that cap is used to cover the loop end that goes inside the 914 altenator or that is what I used it for.
| JeffBowlsby |
Dec 10 2012, 08:50 PM
Jeff that cap is used to cover the loop end that goes inside the 914 altenator or that is what I used it for. Yup I know. Each 914 alternator harness has two of these boots, one at each end of the big red wire. I have been looking for this boot for too long. Problem is the superseded part is GINORMOUS...the cable it fits is about 5/8 in diameter! Whereas the red 914 cable is only ~1/4 in. diameter. The superseded part is no where close to a good fit. |
| euro911 |
Dec 10 2012, 08:58 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,951 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
What DOES that large boot fit then?
| biosurfer1 |
Dec 10 2012, 09:03 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Lo-Fi Version | Time is now: 28th November 2026 - 12:24 PM |
