Rear trailing arm inner ear bolt thread size |
ChrisReale |
May 15 2003, 06:35 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
The bolt that bolts the trailing arm to the inner rear suspention "ear", I know the outer size is 22mm, but what is the thread size that I need? Thanks
Aaron Cox |
May 15 2003, 06:37 PM
take it to your local hardware place and screw it into one of their jigs. it tells you what thread pitch it is and everything.
that is if you get no intelligent answers from people on the list (IMG:style_emoticons/default/smile.gif) (such as this one (IMG:style_emoticons/default/biggrin.gif) ) |
Mueller |
May 15 2003, 06:41 PM
Factory = M14 2.00
Mine = M14 1.5 (shamless plug for my trailing arm kit (IMG:style_emoticons/default/smile.gif) ) |
Jeroen |
May 15 2003, 06:45 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey Mike,
Does your rear bearing kit come with new shafts as well? cheers, Jeroen |
mskala |
May 15 2003, 07:58 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
QUOTE(Mueller @ May 15 2003, 07:41 PM) Factory = M14 2.00 Mine = M14 1.5 (shamless plug for my trailing arm kit (IMG:style_emoticons/default/smile.gif) ) Mike, are you sure about that 2.0? I could swear I stuck a standard 14mm 1.5 lug nut on there over the winter (not for driving). Mark S. '70 914-6 |
ChrisReale |
May 15 2003, 08:18 PM
I'll get one of each to save the hassle. Thanks
Mueller |
May 15 2003, 08:42 PM
Mark,
You are correct, the factory axle is M14 1.5 (same as the lug bolts) I didn't double check what I wrote before taking off from work. (yes, it took me this long to make it home...gotta love driving if you like affordable homes in this area ) Jeroen, Yep, brand new axles with studs similar to the factory set up. Installed a set on Rich Bontempies FP(?) race car yesterday (IMG:style_emoticons/default/MDB2.gif) |
ChrisFoley |
May 15 2003, 08:43 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Hey Chris,
The trailing arm is held on by a nut, not a bolt. The stock pivot shaft has studs coming out of the ends. The nut that holds it on the suspension ear has a special self locking feature, so no lock washer is necessary. (IMG:style_emoticons/default/smile.gif) |
ChrisReale |
May 15 2003, 08:54 PM
Yea, I meant to say nut. My "special, self-locking" feature is not working anymore (IMG:style_emoticons/default/sad.gif)
Jeroen |
May 16 2003, 03:42 AM
QUOTE(Mueller @ May 16 2003, 04:42 AM) Jeroen, Yep, brand new axles with studs similar to the factory set up. Installed a set on Rich Bontempies FP(?) race car yesterday (IMG:style_emoticons/default/MDB2.gif) Great! One less part to worry about 'cause even the shafts in the rear control-arms that came off my car are rusted (IMG:style_emoticons/default/mad.gif) cheers, Jeroen |
brant |
May 16 2003, 08:36 AM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mike M,
are you coming up with any spare stock shafts after people convert. I friggin can't find my pair of stock shafts that I was going to put back into the street car.. They should be here, but have yet to been found.. So I'm wondering if there are extra used shafts out there? brant |
Mueller |
May 16 2003, 10:17 AM
Hey Brant,
Yep, I should have at least 3 pairs of extra stock axles...I'll try to find a set and send them to you next week. Just cover shipping and they are yours. Mike |
brant |
May 16 2003, 10:29 AM
absolutely... but I'll be happy to pay too...
I'll send you a pm to get info. brant |
Lo-Fi Version | Time is now: 12th June 2024 - 03:18 PM |
