tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
What is the best way to remove a glued-on rear view mirror from the windshield without damaging the windshield?
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
It isn't glued on. It has an adhesive patch that fits to the back of the mirror base and gets stuck to the windshield. Use a very sharp razor blade to remove it.
(IMG:style_emoticons/default/sawzall-smiley.gif) Or a Sawzall if you're going to replace the windshield (IMG:style_emoticons/default/biggrin.gif) |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
I have used penetrating oil, but the windshield wasn't attached.
I can't say for certain if that helped but I couldn't get it off before trying that. I have heard of them separating the glass with the forced required to remove them. |
tumamilhem |
It isn't glued on. It has an adhesive patch that fits to the back of the mirror base and gets stuck to the windshield. Use a very sharp razor blade to remove it. (IMG:style_emoticons/default/sawzall-smiley.gif) Or a Sawzall if you're going to replace the windshield (IMG:style_emoticons/default/biggrin.gif) Well, it's not an OEM rear view mirror and it's really hazy from behind so it's not easy to see out of. So I want to remove it and put an OEM one on. I have one on my other car if I can't find one, but I'll need to find out how to remove that one. This windshield is new, so I don't want to damage it. |
ConeDodger |
See that's relevant information. Who knows how a non-stock RVM was put on? (IMG:style_emoticons/default/huh.gif)
Well, all I can say is heat activates adhesive then use the very sharp razor method. Not too much heat and not too concentrated. Just get the window nice and warm and try and force the razor blade behind it. Adhesive remover to remove the goo on the window when you're done. |
7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
Heat up the glass with a hair dryer and wiggle it off
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
+1 Don't burn it, you can delaminate the glass, just get it pretty hot. I have a single sided razor scraper that I use to go around while it's hot. Pops them right off, then the razor to clean up the residual glue.
tumamilhem |
Once I have the mirror off, how can I remove the residue to get a good clean surface and where do I get this adhesive strip to re-attach? Thanks for your input, guys! (IMG:style_emoticons/default/smile.gif)
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Have you ever wondered why it's called a rear view mirror. I mean, what else would you view with a mirror...a front view? (IMG:style_emoticons/default/confused24.gif)
Oh yeah, you can clean up the adhesive residue with some lighter fluid, or mineral spirits. |
tumamilhem |
Where can I find this adhesive pad to re-attach? I remermber ther e used to be a clear glue you would use and have to press and hold mirror in place for several minutes. It never really lasted that long. Someone mentioned an adhesive pad? What's the best and strongest way to re-attach?
bluhun |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California ![]() |
Where can I find this adhesive pad to re-attach? I remermber ther e used to be a clear glue you would use and have to press and hold mirror in place for several minutes. It never really lasted that long. Someone mentioned an adhesive pad? What's the best and strongest way to re-attach? The adhesive mirror pad can be obtained from the dealer or Pelican Parts ($3.25 ea). I also assume that Automobile Atlanta has them. |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I just put in a new windshield and I had problems with the original mirror staying on the original windshield. The new windshield was so purdy I didn't want to mess it up so I bought a Porsche 914 interior rear view mirror BMW conversion on Ebay. Screws into your sun visor holes and takes it place.
Attached image(s) ![]() |
tumamilhem |
Oh nice! Was that specially made or is it something I can order?
I assume since that's attached to the underside of the top of the windshield trim, it sits a bit higher that original placement for original? How is your view? Is it too high to where the roll bar is obstructing your view? |
JawjaPorsche |
It is a little higher than normal but no problems. The vendor makes these and sells on Ebay:
http://www.ebay.com/itm/Porsche-914-interi...mp;cmd=ViewItem Oh nice! Was that specially made or is it something I can order? I assume since that's attached to the underside of the top of the windshield trim, it sits a bit higher that original placement for original? How is your view? Is it too high to where the roll bar is obstructing your view? |
7TPorsh |
I just put in a new windshield and I had problems with the original mirror staying on the original windshield. The new windshield was so purdy I didn't want to mess it up so I bought a Porsche 914 interior rear view mirror BMW conversion on Ebay. Screws into your sun visor holes and takes it place. I did this too...highly recommend...clean look from outside the car. |
Madswede |
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains ![]() |
I just put in a new windshield and I had problems with the original mirror staying on the original windshield. The new windshield was so purdy I didn't want to mess it up so I bought a Porsche 914 interior rear view mirror BMW conversion on Ebay. Screws into your sun visor holes and takes it place. I'm glad I found this (search function is your friend ... once you get used to using it (IMG:style_emoticons/default/poke.gif) ) Thanks for posting about it! I'm definitely going to try this. I'm tall enough where the sun visors were rarely used and actually got in my line of sight about as often as they were needed, and I live in the high desert of New Mexico where we get rain about 10 days per year, or so it seems. So I'm going to buy this, install it, and try it out. (IMG:style_emoticons/default/sunglasses.gif) |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
It isn't glued on. It has an adhesive patch that fits to the back of the mirror base and gets stuck to the windshield. Use a very sharp razor blade to remove it. (IMG:style_emoticons/default/sawzall-smiley.gif) Or a Sawzall if you're going to replace the windshield (IMG:style_emoticons/default/biggrin.gif) .....S&W, target practice 1st (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)(make sure nobody's sitting inside..LOL) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:45 PM |
