Cracks in H2O 914 wheel wells, I recall a discussion, can't find the thread. |
ruby914 |
Dec 31 2012, 01:08 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I recall a discussion about cracks in front wheel wells, just over the radiator exhaust openings. I know my opening is small but if this is a flex and stress point I would like to reinforce the area.
I cut some doublers for the area marked in yellow but before I weld them in I would like to see where the fenders were cracking again. Anyone recall seeing this? (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
scotty b |
Dec 31 2012, 07:17 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
they crack at the corners of the cuts when people make 90* cuts. Make your edges nice and round, and as you said, I would definitely make a double/outilned edge outof some 18 gauge and make the edge thicker.
Now...tell us about that ductwork (IMG:style_emoticons/default/popcorn[1].gif) Me likey (IMG:style_emoticons/default/beerchug.gif) |
Gint |
Dec 31 2012, 07:18 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
And radiator/fan. Gotta be a suby you're working on?
scotty b |
Dec 31 2012, 07:30 AM
Well I just went through your thread on NARP. Nice work on the shroud. I've been dabbling with a one off fiberglass bumper so I guess a fan shroud wil be next for me. (IMG:style_emoticons/default/smile.gif)
Mike and others http://z8.invisionfree.com/ClubNARP/index.php?showtopic=5431 |
ruby914 |
Dec 31 2012, 12:32 PM
they crack at the corners of the cuts when people make 90* cuts. Make your edges nice and round, and as you said, I would definitely make a double/outilned edge outof some 18 gauge and make the edge thicker. Now...tell us about that ductwork (IMG:style_emoticons/default/popcorn[1].gif) Me likey (IMG:style_emoticons/default/beerchug.gif) Yes Scooty all corners are rounded and the doubler will go on the far side. I think I should bend the edge of the doubler to give it a small lip and add rigidity. My plan is to tie it in to the fire wall and the horizontal shelf in the front trunk. I am sure what I have will do the trick. One of these days I hope to revisit the idea of moving the coolant lines from the bottom center to inside the rocker panels. For one, I think, I could be using smaller ID rubber lines. Then, I keep my eye out for a new path to the forward rocker panel. I found this photo that may work but it is at that stress point again. I see you found my NARP thread. Now my eyes are on what you're up to. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
Andyrew |
Dec 31 2012, 12:40 PM
LOVE that duct work. Thats what I plan on doing when the Audi engine gets installed.
NORD |
Dec 31 2012, 01:05 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
For the hose penatrations, just weld in a tubing sleeve for each hose. (IMG:style_emoticons/default/welder.gif) |
ruby914 |
Dec 31 2012, 03:14 PM
For the hose penatrations, just weld in a tubing sleeve for each hose. (IMG:style_emoticons/default/welder.gif) Excellent! Sometimes it is just that easy (IMG:style_emoticons/default/beerchug.gif) Thanks. |
ruby914 |
Dec 31 2012, 03:23 PM
LOVE that duct work. Thats what I plan on doing when the Audi engine gets installed. Thank you and it is nice to see that Audi come together, looking good. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:37 PM |
