I can fix headers, with a common problem |
ChrisFoley |
May 16 2003, 07:27 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Kerry Hunter Headers (and others) have a common problem. The little ears that go over the studs bend and make it harder to mount. They also crack the pipe sometimes when you tighten the nuts a little more to get rid of that pesky exhaust leak, making things worse.
Attached image(s) |
ChrisFoley |
May 16 2003, 07:30 AM
I can cut those things off and replace them with the machined blocks I use on my stub pipes. You can apply more torque, safely. They line up better with the studs so there is less chance of leaks when torqued carefully.
Attached image(s) |
ChrisFoley |
May 16 2003, 07:32 AM
Price: $175, plus shipping
Brad Roberts |
May 16 2003, 02:32 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The problem I found the most.. people with bent studs. I dont think I have ever ripped any off the stub tube or broken one. Another reason why I use the European racing header (they use a solid piece for the stub tubes also..instead of a bent tab)
B |
SPNR |
May 17 2003, 05:14 PM
Newbie Group: Members Posts: 9 Joined: 20-April 03 From: Castle Rock CO Member No.: 592 |
Brad,
Where for you are having to get EUROPEAN RACING HEADERS for a four? |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:27 PM |
