Flared Front Spoiler, Any Ideas? |
jfort |
Jan 3 2013, 10:37 AM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I would like to achieve something like this. Can't find a vendor. GT-Racing.com has a flared front spoiler, but it has a cut out for an oil cooler, which I don't have. Think about buying it none-the-less and modifying it to look like the picture. Comments? Any other ideas?
front_spoiler.tiff ( 393.46k )
front_spoiler.tiff ( 393.46k ) Number of downloads: 226 front_spoiler.tiff ( 393.46k ) Number of downloads: 226 |
ConeDodger |
Jan 3 2013, 10:39 AM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I think your idea to modify the GT Racing Valence is the way you'll have to go...
ernestj911@gmail.com |
Jan 10 2013, 12:11 PM
Newbie Group: Members Posts: 24 Joined: 20-July 06 Member No.: 6,472 |
this one is really cool.
carr914 |
Jan 10 2013, 01:00 PM
Racer from Birth Group: Members Posts: 118,841 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I think Getty makes one
pete-stevers |
Jan 10 2013, 07:06 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Glass n resin are fun to work with....!! (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea |
Jan 10 2013, 07:07 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Get an oil cooler! (IMG:style_emoticons/default/wink.gif)
PanelBilly |
Jan 10 2013, 07:33 PM
914 Guru Group: Members Posts: 5,810 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
While your at it, make one for me
sixnotfour |
Jan 10 2013, 08:03 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
ruby914 |
Jan 11 2013, 11:00 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
this one is really cool. I have the same spoiler on my flared car. I Cropped off an inch from the bottom and flared it. In order to do this, I mounted the spoiler to the car and Gorilla glued some EPS foam to the area I wanted to flare. I use EPS because I have a lot of extra and I can cut it with a hot wire. I used the flared fender as a guide to cut, sand and shape the foam. If you use EPS foam you will need to use epoxy resin. Polyester resin will eat EPS. If you go to a Michaels or some art or flower shop they may have something that I think is polyurethane foam. Rigid polyurethane foam can be used with polyester resin. I have also seen people use spray foam but it's a bit soft and not so easy to shape. What I am thing of is green or white and has big open cells that may need to be filled with body filler before you glass over it. Be sure you sand and clean any surface you want the resin to bond to. Good luck. Mike Attached image(s) |
DEC |
Jan 12 2013, 06:44 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
Lo-Fi Version | Time is now: 29th May 2024 - 03:37 AM |
