> Styrofoam in the Door?, What's supposed to be in there?
able2222
post Jan 7 2013, 07:44 AM
Doing some window track maintenance on a '70 and pulled the door panels off. Found some large styrofoam blocks in the bottom of the door. Questions: 1. did the factory do this? 2. is it a redneck attempt at sound deading by the PO? or 3. is it an after market floatation assist kit (if it is I'm missing the snorkle)?
Replies(1 - 8)
914itis
post Jan 7 2013, 07:48 AM
Window stopper? (IMG:style_emoticons/default/confused24.gif)
SUNAB914
post Jan 7 2013, 08:08 AM
Not factory.
post Jan 7 2013, 10:07 AM
New to me. My 1st ride in a 914 was in Austin albeit 40 yr's ago. (IMG:style_emoticons/default/dry.gif)
Nine_14
post Jan 7 2013, 10:09 AM
Region Association: Germany
Don't forget there must be a plastic foil behind the door panel.
Tom_T
post Jan 7 2013, 11:27 AM
TMI....
QUOTE(Nine_14 @ Jan 7 2013, 08:09 AM) *
Although here we'd call it a plastic sheet vapor barrier behind the inner door panel & over the inner frame.
That styrofoam was a DAPO add-on, cuz that will only hold moisture to aid tin worm!
Porsche/VW did inject foam in other body cavities in an ill advised attempt to both sound deaden & waterproof the bodies, which instead turned out to cause water-poof! (IMG:style_emoticons/default/blink.gif)
walterolin
post Jan 7 2013, 11:34 AM
Agree with Tom T. I have an August 1970, took the doors off and apart a few months back. Found several tin worms, some loose window regulator parts, and a layer of undercoating on the sheet metal.
My rear fenders had foam injected into the very top corners by the tail lights, one rusted from trapped water.
Nine_14
post Jan 7 2013, 11:42 AM
QUOTE(walterolin @ Jan 7 2013, 06:34 PM) *
Using Foam ? The badest way ever, hope you put this (IMG:style_emoticons/default/stromberg.gif) out
JamesM
post Jan 7 2013, 11:45 AM
My guess is someone put it there to soften the blow of the window crashing down when the lift mechinasim pops out of the little plastic button. I have had this happen a lot with my early cars.
I would check your little plastic button and rollers/guides and make sure nothing is damaged or missing as this can cause occasional binding and then the *pop* and *CRASH* the foam is most likely there to lessen.
- Lo-Fi Version Time is now: 26th May 2026 - 02:04 AM
