> aero mirror install, driver side doesnt seem right.
peteyd
post Jan 9 2013, 11:36 AM
My car is currently at the body shop, and they guys just finished putting on the mirrors. The passenger side looks good, but the driver side looks like it points too high.
I bought the kit direct from Porsche, so they should be all the correct parts. We did notice that the base the driver mirror sits on is taller than the passenger.
Is this normal?
What have you guys seen in the past? Is there possibly another base that is smaller for the drvr side?
Replies(1 - 11)
peteyd
post Jan 9 2013, 11:38 AM
the passenger side, not as clear of a picture, but you can tell the angles are different
DBCooper
post Jan 9 2013, 11:44 AM
14's in the 13's with ATTITUDE
I don't know about those mirrors, but people have to shape the bottom of the flag mirrors to fit the profile of the 914 doors. You say the driver's side is "mounted higher", so it would be going up the curve into the top part of the door, tilting it like that. Maybe try shaping the base so it tilts further out... better than re-mounting it in the same lower position as the passenger side.
rjames
post Jan 9 2013, 05:53 PM
I'm made of metal
I've never liked anything but a stock mirror on the 914. To me everything else looks a little off. (IMG:style_emoticons/default/confused24.gif)
Mike Bellis
post Jan 9 2013, 07:56 PM
Resident Electrician
They don't mount symmetrically... (IMG:style_emoticons/default/sad.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-10496-1357782972.1.jpg)
peteyd
post Jan 10 2013, 09:21 AM
QUOTE(kg6dxn @ Jan 9 2013, 05:56 PM) *
these mirrors dont look like they are at such an extreme angle as mine though...
Does anyone have first hand experience installing these on their 914?
This was a 964...part number if that makes any difference also.
Thanks,
Pete
Mike Bellis
post Jan 10 2013, 09:25 AM
You need to lower the drivers mirror. Move it down on the door towards the ground. This will level out the top.
From your pic, I would guess it needs to move down 1 inch or so.
Mikey914
post Jan 10 2013, 11:30 AM
The rubber man
I had 928 mirrors on my old car. I thought they were 944 untl I went to replace the base gasket and found out it was the 928 base.
carr914
post Jan 10 2013, 01:08 PM
Racer from Birth
I don't think either one of your Aeros are mounted correctly
You definately have to machine down the Bases of these or Flags to fit correctly
DBCooper
post Jan 10 2013, 02:14 PM
QUOTE(kg6dxn @ Jan 10 2013, 07:25 AM) *
Yeah, but don't re-drill mounting holes. Do what T.C. suggests, re-shape the mirror bases so you get the angle you want with the mirrors in the same mounting holes they're already in.
peteyd
post Jan 10 2013, 03:01 PM
Ok,
I will reshape the bases. I dont plan on changing the passenger side because it looks fine to me, but the driver side needs attention.
Thanks for all the help and suggestions.
Pete
Dave_Darling
post Jan 10 2013, 03:59 PM
914 Idiot
QUOTE(peteyd @ Jan 9 2013, 09:36 AM) *
There are no "correct parts" for this mod. Fitting these will be just like fitting aftermarket mirrors that were designed for some other car. Adjustment, fitting, trimming, possibly shimming, and more modifications may all be required.
Figure out how to make it work, and don't sweat having to alter the parts. Because they're not the "right" ones anyway. (IMG:style_emoticons/default/smile.gif)
--DD
- Lo-Fi Version Time is now: 25th November 2026 - 04:53 PM
