another way to run fuel lines |
rhodyguy |
Jan 10 2013, 02:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,088 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
with all the carb talk these days i thought i'd share a dif way to run your fuel lines.
these are the appropriate sized fuel lines compatible with our modern fuels. from the tee to cross over to the other carb i used 2 rubber isolated camps thru the holes in the rear upright tin. i split a piece of vac line, wrapped the fuel line in the vac line and it fits perfectly in the groove in the engine side of the tin. the holes in the tin serve double duty. i put another set of clamps on the rear of the tin on the same bolts to keep the hot starter wire secure and and off the trans. while the clamps hold the hose/wire securely it doesn't pinch anywhere. i think this method helps with fuel temps keeping the fuel line as far away from the engine heat and no direct contact with any metal while securing it. lmn what you all think. k Attached thumbnail(s) |
7TPorsh |
Jan 10 2013, 03:29 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I brought mine up top on the backside to a tee then into the carbs. I was worried about the fuel heating up around the tin.
last337 |
Jan 10 2013, 03:59 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
i have mine coming up from under battery to a tee then splitting to each carb with one line going across under engine compartment cover. I am a bit worried that having the tee so much closer to one carb will affect the fuel flow to each carb but I guess I will know more if I cant get them balanced correctly.
rhodyguy |
Jan 10 2013, 05:37 PM
by cover you mean the lid?
aircooledtechguy |
Jan 10 2013, 08:29 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
[quote name='last337' date='Jan 10 2013, 01:59 PM' post='1800098']
I am a bit worried that having the tee so much closer to one carb will affect the fuel flow to each carb but I guess I will know more if I cant get them balanced correctly. The "T" can be anywhere between the two carbs. your fuel pump will ensure that both carbs get all the fuel they need. |
last337 |
Jan 11 2013, 01:55 PM
Lo-Fi Version | Time is now: 4th June 2024 - 09:44 AM |
