Custom hydraulic hoses, Anyone local sells/makes these? |
914_1.8t |
Nov 10 2004, 12:49 PM
Member Group: Members Posts: 302 Joined: 3-June 04 From: East Bay Member No.: 2,149 |
I need to get a hose to run from the pedal cluster back to my tranny and am looking for some hydraulic hoses.
Is there someone local (bay area) that makes customer hydraulic hoses or sells them? |
mattillac |
Nov 10 2004, 01:55 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
why not use a hardline for most of the length you need and adapt some brake lines or something at each end? just and idea. tools and supplies to flare your own brake/hydraulic lines are pretty cheap.
Mueller |
Nov 10 2004, 02:32 PM
QUOTE(mattillac @ Nov 10 2004, 12:55 PM) why not use a hardline for most of the length you need and adapt some brake lines or something at each end? just and idea. tools and supplies to flare your own brake/hydraulic lines are pretty cheap. that would be fine if the threaded fittings are indeed brake line style fittings... |
mattillac |
Nov 10 2004, 02:49 PM
QUOTE(Mueller @ Nov 10 2004, 12:32 PM) QUOTE(mattillac @ Nov 10 2004, 12:55 PM) why not use a hardline for most of the length you need and adapt some brake lines or something at each end? just and idea. tools and supplies to flare your own brake/hydraulic lines are pretty cheap. that would be fine if the threaded fittings are indeed brake line style fittings... true. just throwing out ideas. or maybe throwing up ideas? (IMG:style_emoticons/default/barf.gif) |
914GT |
Nov 10 2004, 03:00 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I'd consider steel tubing if running down the center tunnel, then flex brake line or custom hose to the slave cylinder. This is only from experience of having to replace hoses every 5 years or so on an Acura. It would suck to have a rubber hose burst inside the tunnel and making a mess of things, in addition to having to pull it all out and replace it.
For custom hydraulic hoses, see if you can find a Granberry Supply in your area. http://www.granberry.com/default.asp |
914_1.8t |
Nov 10 2004, 04:58 PM
QUOTE(914GT @ Nov 10 2004, 01:00 PM) I'd consider steel tubing if running down the center tunnel, then flex brake line or custom hose to the slave cylinder. This is only from experience of having to replace hoses every 5 years or so on an Acura. It would suck to have a rubber hose burst inside the tunnel and making a mess of things, in addition to having to pull it all out and replace it. For custom hydraulic hoses, see if you can find a Granberry Supply in your area. http://www.granberry.com/default.asp Thanks, I'll give em a call tomorrow. The problem is that on either end (master cyl and slave cyl) it requires a unique fitting that i believe is specific to the audi trannies/ms. I will have to take the stock hosing/fitting and cut the hose, then add my hose in between. |
mattillac |
Nov 10 2004, 07:05 PM
talk to your local machine shop. maybe they can make you some adapters to attatch a standard sized fitting to?
Trekkor |
Nov 10 2004, 07:19 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Call Jim Cole at B&B Foriegn Car service in Napa
He can make a custom line for you with any fittings you need. 707-255-7588 KT |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:45 AM |
