trans input shaft seal, how deep is OK? |
machina |
Nov 10 2004, 04:50 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Pulled the tranny to change leaking seal. Really masacred the old one even though I had a seal puller. (also put a nice scratch in the bore) (IMG:style_emoticons/default/mad.gif)
Anyway I used the guide tube to seat the seal evenly but it is not as deep as the old one which was almost flush with the case edge. Do I need to tap it in more? Also, the spring came out of the old one and it was all the way inside the tranny (on the shaft of course) Had a second of OMG but was able to fish it out. |
ChrisFoley |
Nov 10 2004, 05:22 PM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If it interferes with screwing the guide tube down tightly then you should tap it in a little further.
TheCabinetmaker |
Nov 10 2004, 07:27 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just did this last week. Purchased a new seal from my local P-car shop. Got the tranni out and the new one looked different from the old one. Called them and found I had an original seal. It has a lip on it that will let it only go so far in. Not available anymore. Press it in till it is flush with case that surounds it. Don't push it too far, as it will end up on the shaft where you pulled the spring from.
McMark |
Nov 10 2004, 07:29 PM
I just did it too! Put it in enough that you can bolt down the guide without interference and call it done. |
machina |
Nov 10 2004, 07:35 PM
thanks guys,
the old one looked OK before I ripped it out of there, but it was leaking like a faucet. Anyway, I'm getting good at pulling the tranny, starter, CV's, exhaust , cables, etc....... (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:32 AM |
