> carpet glue to use?
jdlmodelt
post Jan 15 2013, 08:26 AM
James D. Lane
What adhesive do I need to use to secure the carpet?
Replies(1 - 10)
jdlmodelt
post Jan 15 2013, 09:48 AM
James D. Lane
is the carpet glued in on the 72 or how is it secured?
bump!
McMark
914 Freak!
You only need to glue the side/longitudinal pieces, and the forward inner fender pieces. Do yourself a favor and don't glue down the floor pieces or the center tunnel piece. You will be in a situation where you want those pieces out in the future. I'll bet $5 on it. (IMG:style_emoticons/default/wink.gif)
3M HiStrength 90 Spray Adhesive.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.soundtechco.com-419-1358264932.1.jpg)
jdlmodelt
post Jan 15 2013, 09:54 AM
James D. Lane
thank you! (IMG:style_emoticons/default/beerchug.gif)
tod914
post Jan 15 2013, 11:09 AM
You can get away with no glue. The longs are held in place by the threshold strips and speaker pods. None of my carpet pieces are glued in. It's a mess to undue like Mark mentioned. Velcro strips might be a good alternative.
AvalonFal
post Jan 15 2013, 04:06 PM
On the longs, I just used regular double sided carpet tape. Holds the carpet in place and easy to peel off. Used nothing on the floor and tunnel sections and I'm glad because I've pulled them up several times since installing.
Paul
andys
post Jan 15 2013, 04:12 PM
I went with carpet tape as well, though I did do the floor sections. For me, they slide around too much if you don't.
Andys
Drums66
post Jan 15 2013, 04:34 PM
914 Rudiments
....Don't do it!..Don't glue it! (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif)
tod914
post Jan 15 2013, 06:48 PM
What brand carpet tape did you guys use? The stuff I got at Home Depot wouldn't stick to the backing of the carpet.
jdlmodelt
post Jan 15 2013, 07:55 PM
James D. Lane
QUOTE(Drums66 @ Jan 15 2013, 03:34 PM) *
I won't glue it. I'll try carpet tape if there is some consensus as to what kind to use?
larss
post Jan 15 2013, 11:20 PM
QUOTE(AvalonFal @ Jan 15 2013, 11:06 PM) *
Paul
- Lo-Fi Version Time is now: 18th September 2026 - 10:43 PM
