Proud New Owner, I got to enjoy this beautiful girl for a week before I had a starting issue. looking for help with any diagnostic |
wolfeman1727 |
Jan 23 2013, 11:45 PM
Newbie Group: Members Posts: 8 Joined: 4-November 12 From: Stockton, CA Member No.: 15,113 Region Association: Central California |
Hi all,
I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in. I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me. It doesn't get gas -replaced the fuel pump -replaced the filter still no avail The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over. Im not getting the power -replaced relay -cleaned all connections on the regulator plate Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit. Any Ideas?? I miss driving the darn thing! (IMG:style_emoticons/default/pray.gif) |
rick 918-S |
Jan 23 2013, 11:59 PM
Hey nice rack! -Celette Group: Members Posts: 20,506 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
You may have a bad relay board or a bad replacement relay. Take a relay from one of the headlight motors and try that. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) (IMG:style_emoticons/default/assimilate.gif)
Dave_Darling |
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Fuel injected? If so, the ECU ("brain") grounds one pin of the relay to run the fuel pump. It will do that for about 1.5 seconds when the key goes from "off" to "on", then again while the starter is cranking, and also when the engine is running over about 50 RPM.
That assumes the D-jetronic injection that was originally used on all of the 1.7 and 2.0 914s. The 1.8's L-jetronic injection ran the pump when the flap in the air meter was opened. Carb setups will typically run the pump while the key is on, but that is up to the person who converted the car to carbs. Brad Anders has a troubleshooting flowchart on his D-jet site: http://members.rennlist.com/pbanders . --DD |
Elliot Cannon |
Jan 24 2013, 12:33 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Are you anywhere close to Paso Robles?
wolfeman1727 |
Jan 24 2013, 01:11 AM
All the connections on the board looked good, and I swapped several relays just for fun.
I will confirm connections on the plate with a meter tomorrow and see if there are any issues there. The system is definitely D-jet |
wolfeman1727 |
Jan 24 2013, 01:12 AM
I'm currently out of Stockton, Paso Robles would be a little bit of a drive haha
Jeffs9146 |
Jan 24 2013, 01:14 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Hi all, I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in. I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me. It doesn't get gas -replaced the fuel pump -replaced the filter still no avail The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over. Im not getting the power -replaced relay -cleaned all connections on the regulator plate Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit. Any Ideas?? I miss driving the darn thing! (IMG:style_emoticons/default/pray.gif) There are a few of us that are within 30 minutes of you! I am in Discovery Bay and at least 4 others are close too! If you need some eyes I am sure we could find someone to come out help you get it going again! It sounds like your relay or your Fuel Pump is having an issue. |
76-914 |
Jan 24 2013, 12:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
here ya go.......... http://members.rennlist.com/pbanders/FPChecklist_frame.htm
mtndawg |
Jan 24 2013, 12:28 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Come on wolfeman! A new owner post with no pics. A picture is worth 1000 words.
Hi all, I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in. I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me. It doesn't get gas -replaced the fuel pump -replaced the filter still no avail The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over. Im not getting the power -replaced relay -cleaned all connections on the regulator plate Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit. Any Ideas?? I miss driving the darn thing! (IMG:style_emoticons/default/pray.gif) |
wolfeman1727 |
Jan 24 2013, 01:09 PM
ALRIGHT, alright... here's a picture of the new obsession (IMG:style_emoticons/default/laugh.gif)
pt_700 |
Jan 24 2013, 01:10 PM
Senior Member Group: Members Posts: 1,095 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
although rare, the brains do go bad.
my '71 1.7 was down for months as i tried to diagnose issues similar to yours (no signal to the injectors when cranking the motor, in my case). after i broke down and took it to a pro, he spent hours covering the basics before swapping an ecu from a running car and she started right up. good luck and let us know how things turn out. oh, welcome to the madness! |
wolfeman1727 |
Jan 24 2013, 01:20 PM
QUOTE There are a few of us that are within 30 minutes of you! I am in Discovery Bay and at least 4 others are close too! If you need some eyes I am sure we could find someone to come out help you get it going again! It sounds like your relay or your Fuel Pump is having an issue. I'm Going to try and do a little more investigation and research for now, But I greatly appreciate the offer, and may take someone up on it soon. I'll let ya know |
bandjoey |
Jan 24 2013, 02:00 PM
bandjoey Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Filter Inside the gas tank plugged? Run the pump out of a gas can to see if the tank/ line is plugged up.
Old gas varnish plugging up injectors or carb jets? Temporarily run a hot 12v wire to the pump? Great looking car! |
Jeffs9146 |
Jan 24 2013, 02:02 PM
442nd914s |
Jan 24 2013, 05:32 PM
Member Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
(IMG:style_emoticons/default/idea.gif) Do I spy vinyl A pilars? Is this one of those 1000 Ca cars?
As for the fuel pump problem. If it has the original factory wiring. Brown is ground to the fuel pump. I would get a small 5ft jumper wire from the battery and go directly to the + side of the pump to verify the pump works. Step 2. Remove hose from the in of your filter. Gravity should push down the fuel in the tank and spill out. If not then u have a bad fuel line. Obviously this step will only verify fuel to the filter, not your voltage problem. Good luck |
SirAndy |
Jan 24 2013, 06:07 PM
Resident German Group: Admin Posts: 41,691 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/idea.gif) Do I spy vinyl A pilars? Is this one of those 1000 Ca cars? (IMG:style_emoticons/default/agree.gif) Looks like one of the elusive 1000 first of '73 ... (IMG:style_emoticons/default/idea.gif) |
wolfeman1727 |
Jan 24 2013, 06:31 PM
(IMG:style_emoticons/default/idea.gif) Do I spy vinyl A pilars? Is this one of those 1000 Ca cars? (IMG:style_emoticons/default/agree.gif) Looks like one of the elusive 1000 first of '73 ... (IMG:style_emoticons/default/idea.gif) I'm afraid there isn't any vinyl on my pillars, this car was factory white and was painted...sloppily |
wolfeman1727 |
Jan 24 2013, 06:34 PM
The tank was just filled up when I developed this issue... and it all drained nicely from the hose attached to the pump... no clogs or bad lines.
Im pretty confident my lack of voltage is the issue at this point. Time to double check all my fuses and connections |
442nd914s |
Jan 24 2013, 07:14 PM
(IMG:style_emoticons/default/idea.gif) Do I spy vinyl A pilars? Is this one of those 1000 Ca cars? (IMG:style_emoticons/default/agree.gif) Looks like one of the elusive 1000 first of '73 ... (IMG:style_emoticons/default/idea.gif) I'm afraid there isn't any vinyl on my pillars, this car was factory white and was painted...sloppily When I lived in Ca (Compton to be exact) this kind of paint jobs were popular http://m.youtube.com/#/watch?v=PtjdHaMeiiQ...v%3DPtjdHaMeiiQ |
wolfeman1727 |
Jan 28 2013, 10:29 AM
After much touching, unplugging, testing It started right up...
We bypassed the relay to test the pump, which worked beautifully... and then re- installed the relay...and the dammed thing worked. I'm back on the road for now (IMG:style_emoticons/default/driving.gif) Thanks guys! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 04:28 AM |
