qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
Manual says Porsche mechanic only (IMG:style_emoticons/default/laugh.gif)
I was thinking of drilling rubber out to free them up. how do i get them apart and then back together? (IMG:style_emoticons/default/pray.gif) |
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,439 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I just put the arms in a press and pushed the bushings out. They peeled right off with enough pressure, and I didn't piss off my neighbors by floating little bits of burned rubber into their pool. (IMG:style_emoticons/default/biggrin.gif)
When you reassemble and you use delrin bushings, test fit them into the brackets, and slide them over the arms. They should move freely without lubrication. IF they don't ream them until they do. Don't check them without the outside metal collars, the installation into the collars will make the hole in the center smaller. BTDT. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I've found it easier to use a torch and I've got a press sitting in the corner of the garage.
I don't like the out and out flame thrower idea either. Here's what I've found: Have a large screwdriver available and ready to use on those collars that Clay talks about. Using a torch, evenly heat the collar until you see a wisp of smoke come off the rubber bushing. Once they start to smoke they're ready to go. Put the screwdriver in the bolt holes (for the front collars) or the adjustment hole (for the rears) and begin to twist the collar. They may cool enough as to where you will have to heat them again but, by working the screwdriver and collar back and forth they will slide right off. After that it's fairly easy to cut the bushing and remove it from the arm. I put this off for a couple months and couldn't believe that I was done in five minutes (IMG:style_emoticons/default/headbang.gif) Not that tough and about a 1 or a 2 on a 10 scale. Again... don't cook the sheite out of them, just get them warm enough to smoke a bit. My $0.02 (IMG:style_emoticons/default/smash.gif) |
Eric_Shea |
Found some pics...
Not as it looks, this is simply the undercoating flaming off the collar. In the background you can see the rear adjusting collars removed and the bushings cut. Attached image(s) ![]() |
Eric_Shea |
This is more like it. Apply even heat on both side until you see some blue smoke come out from under the collar.
Eric_Shea |
Insert the screwdriver and twist away...
Eric_Shea |
I usually bead blast them after that and repaint with POR-15. Powdercoating is always nice (IMG:style_emoticons/default/biggrin.gif)
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Classic, this has to go to the classic section. Simple, yet descriptive...
Again Eric, you are DA MAN for tech specs. BTW, great pics.... (IMG:style_emoticons/default/smilie_pokal.gif) |
Eric_Shea |
We need a blushing smiley.
Thanks Rob. I like to help. Any recent pics of your project?? |
Lo-Fi Version | Time is now: 9th July 2025 - 01:01 PM |
