Dellorto Fuel Problem, Dellorto Carb Issues |
mharrison |
Nov 12 2004, 12:21 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
I have a pair of 40 DRLA Dellortos on my '72 914. I had some problems with the accelerator pumps, but I removed the pump diaphragm and glew air through the hole to free up the ball bearing like valve in there. Now one is pumping, but the other is not. The accelerator pump arm is moving, it sounds like it is pumping are when off the car, but when I hook the fuel back up, I can't get it to pump. I'm going to pull it apart again and check the float, but do you guys have any pearls of wisdom on anything else that I might be able to check while I've got it off the car?
-Matt |
Toast |
Nov 12 2004, 12:50 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Hummm.....Delorto and fuel problems... (IMG:style_emoticons/default/idea.gif)
Now there is something unusual. (IMG:style_emoticons/default/rolleyes.gif) My solution, get a different set of carbs. |
SLITS |
Nov 12 2004, 01:01 PM
You could feasibly have a pin hole in the diaphram or the flat spring that seats the ball is not functioning correctly.
mharrison |
Nov 13 2004, 11:00 PM
Well on the tear down I still had two frozen check valves. I got those cleared up and pissed off my neighbors tuning with straight pipes for about two hours. It reminds me of the time I first got my '73 2.0 running in 1986. It was about 11 o'clock at night with straight headers in a subdivision. Heh..heh...
Still doesn't want to idle well, but I can keep it running as long as I want to nurse it. I think I'll put my s.s. Heat Exchangers and muffler on tommorow. (I just couldn't bolt my new muffler to those crusty,rusty old heat exchangers!) After that is on, I'll work out the details to keep it running. You know, November is not the best time to be working on this cold natured beast! |
tommy914 |
Nov 14 2004, 02:10 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
November may be a little chilly, but it beats the heck out of May, June, July, August, September heat and humidity.
Nothing I hate worse than breaking a sweat just jacking the car up. I don't suppose Weber Jets will fit the Dellorto's? I have a pretty good selection of jets for the Webers, also have a synchrometer if you need to borrow one. |
Lo-Fi Version | Time is now: 4th June 2024 - 04:08 PM |
