Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
I've been looking for a button head cap screw that I could use with Gotti 3 piece wheels. The screw has to able to take 14 foot pounds of torque (168 inch pounds), so the normal versions you can find break. By switching to socket head cap screws the torque issue.s goes away, but socket heads have a higher profile than I would like. I know the Gotti folks sell, for about a buck apiece, the button heads that will take the torque, but would like to find a US supplier. Need M6 x 35mm. |
McMark |
My unenducated research says that a M6 bolt that can take 14 ft/lbs would be grade 12.9. McMaster-Carr sells some but they are 'normal' allen head, not button. PN: 91290A334
Plus they're a black finish. But $11 for a pack of 100. (IMG:http://www.914world.com/bbs2/uploads_offsite/images1.mcmaster.com-419-1359666642.1.png) Here's a couple other options randomly found via Google (search: M6 12.9 button bolts) https://www.boltmax.com/proddetail.php?prod=535078 http://www.mandsfastener.com/M6-Button-Hea...Screw_p_75.html I would probably try and confirm with Gotti techs before using any of these. |
Randal |
My unenducated research says that a M6 bolt that can take 14 ft/lbs would be grade 12.9. McMaster-Carr sells some but they are 'normal' allen head, not button. PN: 91290A334 Plus they're a black finish. But $11 for a pack of 100. (IMG:http://www.914world.com/bbs2/uploads_offsite/images1.mcmaster.com-419-1359666642.1.png) Here's a couple other options randomly found via Google (search: M6 12.9 button bolts) https://www.boltmax.com/proddetail.php?prod=535078 http://www.mandsfastener.com/M6-Button-Hea...Screw_p_75.html I would probably try and confirm with Gotti techs before using any of these. The socket head screws torque fine, i.e., haven't had one break yet. No so with the button head ones, unless you buy them from Gotti. I'll check those links Mark. Thanks. |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
Because of the federal Fastener Act all fasteners are required to have a head marking. If you can show me the head marking I can tell you who made it so you can go to the source.
ARP might have something also If you can get a photo send me a PM in case I don't see your posting here. DAvid |
Randal |
My unenducated research says that a M6 bolt that can take 14 ft/lbs would be grade 12.9. McMaster-Carr sells some but they are 'normal' allen head, not button. PN: 91290A334 Plus they're a black finish. But $11 for a pack of 100. (IMG:http://www.914world.com/bbs2/uploads_offsite/images1.mcmaster.com-419-1359666642.1.png) Here's a couple other options randomly found via Google (search: M6 12.9 button bolts) https://www.boltmax.com/proddetail.php?prod=535078 http://www.mandsfastener.com/M6-Button-Hea...Screw_p_75.html I would probably try and confirm with Gotti techs before using any of these. You ended up being right Mark. A button head cap screw in M6 can only take 88 inch pounds of torque. A socket head can take 168 inch pounds, but is a higher profile than I like. The button heads that Gotti sells will take the higher torque, but must be something special beyond the 12.9 specification. |
Lo-Fi Version | Time is now: 16th June 2024 - 05:56 PM |
