QUOTE(McMark @ Jan 31 2013, 01:10 PM)
My unenducated research says that a M6 bolt that can take 14 ft/lbs would be grade 12.9. McMaster-Carr sells some but they are 'normal' allen head, not button. PN: 91290A334
Plus they're a black finish. But $11 for a pack of 100.
Here's a couple other options randomly found via Google (search: M6 12.9 button bolts)
https://www.boltmax.com/proddetail.php?prod=535078http://www.mandsfastener.com/M6-Button-Hea...Screw_p_75.htmlI would probably try and confirm with Gotti techs before using any of these.
You ended up being right Mark. A button head cap screw in M6 can only take 88 inch pounds of torque. A socket head can take 168 inch pounds, but is a higher profile than I like.
The button heads that Gotti sells will take the higher torque, but must be something special beyond the 12.9 specification.
