auto trans axle, Stupid Question |
bernbomb914 |
May 16 2003, 11:18 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I said it was a stupid question. I have not seen a 944 auto transaxle. Would it be possible to put one in a 914 and bolt up a motor? An old mechanic said it would work.
Bernie (IMG:style_emoticons/default/confused24.gif) |
Red-Beard |
May 16 2003, 11:47 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Old as in having senile dementia?
The 944 was a front mounted engine with a transmission behind the engine and a differential in the rear of the car. No, it will not fit. |
Mueller |
May 16 2003, 11:55 PM
Are you sure?, i really thought the 944 used a transaxle similar to the 928.
(motor in front with a torque tube connecting the two, the driveshaft was inside the torque tube) I've never seen the bell housing, but I'd say that it's possible they used the same pattern as an Audi and I know adapter plates are available for those. |
bernbomb914 |
May 16 2003, 11:56 PM
he said they were transaxles
Bernie |
Red-Beard |
May 17 2003, 12:11 AM
Mike9142.0 |
May 17 2003, 12:14 AM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
The 944 auto is in the back. The bigest problem that I see is that the starter is mounted on the torque tube up front. The trans has no place for the starter to mount.
Lawrence |
May 17 2003, 07:09 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
You could always attempt a Sporto conversion... ;-)
Drums66 |
May 17 2003, 03:46 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
If you really and truly want to do that? I've heard some Mechanic's say find a 411 vw or 412 with an auto trans, it should bolt right up! (IMG:style_emoticons/default/wink.gif)
Aaron Cox |
May 17 2003, 03:52 PM
QUOTE(Mueller @ May 16 2003, 09:55 PM) Are you sure?, i really thought the 944 used a transaxle similar to the 928. (motor in front with a torque tube connecting the two, the driveshaft was inside the torque tube) I've never seen the bell housing, but I'd say that it's possible they used the same pattern as an Audi and I know adapter plates are available for those. i too thought that for better handling/weight distrobution, the trans was out in the back |
bernbomb914 |
May 17 2003, 04:02 PM
I was told you cant flip the ring gear. no space in the housing.
Bernie |
Aaron Cox |
May 17 2003, 04:05 PM
why would one want a 944 trans anyway? why not a 915 flipped? or a 915 w/ flipped ring gear etc.....why not a 930?
Aaron Cox |
May 17 2003, 04:06 PM
also...just out of sheer curiosity....what trans did a 917 have? and a 908 or 910 or a 904? what did these cars have...midengined right?
bernbomb914 |
May 17 2003, 04:15 PM
We were talking about an automatic trans. The bugs use type 3 autos for drags up to 500hp very strong.
Bernie |
Aaron Cox |
May 17 2003, 04:18 PM
sorry, my bad----- auto trans
Mike T |
May 17 2003, 06:15 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I have seen a 914 with an Audi 5000 automatic transmission in it. It also had a Supercharged 2.0 engine. It was an SCCA autocross car. Ran E-Modified. It was also at least 10 yrs ago. Don't know any other details.
Guys name was William Crescenzo from Kansas City MO. I bet Kennedy Engineered Products would make an adapter for it if they don't already. I know they make a Chevy V8 to Audi transaxle adapter already. Mike T |
dan10101 |
May 17 2003, 06:57 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Just so its solid, the 944's do have a rear trani, very simular to ours. My dad mistakes my spare trani for his, from time to time.. I would think that it might be possible to do a conversion, but the 915 trani makes more sense.
Ok, this is andrew saying this, not dan... stupid computer swaping |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:06 PM |
