> Interior light switch wiring question., Door switch to interior light wire path.
steuspeed
post Feb 5 2013, 04:55 PM
My Interior light works fine in the always ON position, but my door switches are not operating the light when you open the doors. There is no continuity between the interior light and the gray/brown wires at the door switches. Does anyone know the path of the wiring from the interior light to the door switches? The wire at the interior light is brown with gray paint on it. The wires at the door switches are gray with brown paint on them. There must be someplace where they connect?
Replies(1 - 8)
76-914
post Feb 5 2013, 07:12 PM
IIRC, it goes down the tunnel in the main harness. There is one brown switching ground that doesn't go below but around & behind the drivers seat, alongside the long and into the cross brace where it connects to the E brake.
TheCabinetmaker
I drive my car everyday
Is this a new switch?
steuspeed
post Feb 5 2013, 07:28 PM
No, these are original switches. The driver one is sticking a bit, but there is no continuity from the switch to the light. The ground wires at both ends all check out. I would like to get new switches and rubber seals if they are available.
JeffBowlsby
post Feb 5 2013, 07:32 PM
Here is the diagram.
Larry.Hubby
post Feb 5 2013, 10:12 PM
Member who doesn't post much, but has a long time in 914s
The grey/brown wires at the door switches are for the key-still-in-the-igniton-switch-with-the-door-open buzzer. They aren't connected to any of the wires at the interior light, so it's not surprising that your ohmeter can't find a connection. It's the brown/grey wire and the brown wires that are involved with the interior light. With either door open, they should all be connected to both the brown/grey wire at the light and to ground. The difference between brown/grey and grey/brown wires is that the first color is that of the basic wire (the background color) and the second color is that of the tracer, but you probably knew that.
dfelz
post Feb 5 2013, 10:27 PM
beach bum
anyone have some pictures of the wire going behind the drivers seat and where it terminates? would also be interested in seeing the wires connected at the door, mainly where they are connected.
thanks
luskesq
post Feb 5 2013, 10:33 PM
Before chasing wires, I'd confirm with the ohm meter whether the switch (no wires attached) is functioning. If so you can eliminate it from being the source of your problem.
Keith
steuspeed
post Feb 7 2013, 07:39 PM
@Larry OOOOOOHHHHhhhhhhh.... I just need the brown wires to connect to ground. I pulled my door buzzer relay so the GR/BR wires do nothing.
@Keith The door switches are working, but the drivers sticks a bit. I checked them with no wires connected.
@Jeff The color schematic is very helpful. I need a big one of those.
@David I'll try and snap a pic for you next time I take the door switch out.
- Lo-Fi Version Time is now: 11th July 2025 - 05:08 PM
