| stateofidleness |
Feb 10 2013, 07:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Gents,
In the middle of a teardown and cleaning up the tin and stuff... I have a '73 1.7 with A/C and one of the tin pieces fits kind of goofy. I want to straighten it out before painting, but I'm not sure how it's supposed to fit... I've attached a few pics showing different angles of it before removal. I'm wondering if that indented part where the screw is on top is supposed to be dented in like that or perfectly domed? It doesn't seem like that rise is tall enough to allow the flat part of the tin to sit flat. In the 3rd pic, you can see where I hammered it out and it seems a little better, but I was hoping someone was familiar with this tin piece and could confirm what it's supposed to look like. Any reference pics of it? ![]() ![]() ![]() ![]() |
| dlee6204 |
Feb 10 2013, 07:50 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I've never seen this part. It goes on the brake reservoir? Got a pic with it on? It's not suppose to be dented. I'll post a picture if I have one. Slight Hijack: How was your compressor driven off the front of the motor? (IMG:style_emoticons/default/rolleyes.gif) |
| stateofidleness |
Feb 10 2013, 07:53 PM
There's a pulley on the front of the impeller fan. Compressor mounted on a steel bracket just above the fan housing with a centered pulley on the compressor.
| CMONNETT |
Feb 10 2013, 07:56 PM
Member ![]() ![]() Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
It should be flat. It looks quite different from other 914's I've had with AC. The way the tin is cut is what I'm referring to.
| dlee6204 |
Feb 10 2013, 07:57 PM
| stateofidleness |
Feb 10 2013, 08:05 PM
Awesome pic! Didn't even cross my mind that mine was cut out on that one side like that. That's where my big steel bracket thing is bolted to and goes up and lays flat on top (a big "L" shaped piece that goes up the side and lays flat on top of the housing.
You can see in my second pic the "seam" on that piece appears to have been cut or broken at some point. Should I weld that seam closed? |
| dlee6204 |
Feb 10 2013, 08:11 PM
QUOTE You can see in my second pic the "seam" on that piece appears to have been cut or broken at some point. Should I weld that seam closed? Yup, weld away. |
| stateofidleness |
Feb 10 2013, 08:15 PM
You guys are awesome! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 11th November 2026 - 04:15 AM |
