new cap screws for mirror |
siverson |
Feb 14 2013, 12:22 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Yes, my car is still in a million pieces, but I had to order some other hardware and these always bothered me. Even when new I seem to mangle them with the wrong screwdriver.
http://www.mcmaster.com/#catalog/119/3103/=lgxhms Ok, maybe I should get the suspension and drive train back in now... -Steve Attached image(s) |
Chris H. |
Feb 14 2013, 09:34 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Thanks for the info! Those look great. Never seen mirror screws that weren't slightly mangled either.
JmuRiz |
Feb 14 2013, 10:21 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
That's nice, I have two good ones and two mangled ones when I disassembled my car.
What size did you get...just wondering, as my car isn't with me at the moment. |
siverson |
Feb 14 2013, 10:07 PM
M6 x 12. This one:
http://www.mcmaster.com/#cadinlnord/93395a354/=lhec4g I love their web site. (IMG:style_emoticons/default/smile.gif) -Steve |
johnpierre |
Feb 16 2013, 01:48 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
So cool that you have sorted that out. My screws are rusted out. But the way when I go to replace the screw will anything fall to the bottom of the door? Do i have to take the door panel off or can I just change out the screws one at a time with out any issues? Thanks again for the tip jp.
dlkawashima |
Feb 16 2013, 02:40 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
There should be threaded holes inside the door skin and the screws should thread into them.
rfuerst911sc |
Feb 16 2013, 05:51 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Did you alter the finish on the mirror base ? I thought they were chrome like the mirror housing ? I do like the idea of the screws you are using.
jersey914 |
Feb 16 2013, 08:37 AM
Member Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States |
Did you drill out to hit those thread locations or were the holes already there? The PO over 74' filled them in with weld so I cant drill out from the inside. the bit just rolls of the weld. It also piratically impossible to drill what you cant see.
(IMG:style_emoticons/default/WTF.gif) |
siverson |
Feb 17 2013, 12:26 PM
No. AFAIK, all doors have the nuts welded to the inside, it's just most don't have the passenger side holes drilled yet. > Do i have to take the door panel off or can I just change out the screws one at a time with out any issues? Right, just one at a time. It's super easy. > Did you alter the finish on the mirror base ? I thought they were chrome like the mirror housing? Right - that mirror is weird. All I've seen are chrome everywhere, as is my driver side. This was a NOS mirror I ordered a couple years ago and it just came like this. It bothered me at least, now I just think it's "unique". > Did you drill out to hit those thread locations or were the holes already there? I drilled the top door skin several years ago, but like I said above, I'm pretty sure all doors have the nuts welded on the inside, it's just a matter of finding the right spot on top (drill a very small pilot hole from the inside, or measure VERY carefully. (IMG:style_emoticons/default/smile.gif) ). -Steve |
dlkawashima |
Feb 17 2013, 05:06 PM
To find the correct location to drill the holes for the side mirror, I used a spring loaded center punch as mentioned in the thread below. Easy & accurate.
http://www.914world.com/bbs2/index.php?showtopic=93657 |
Drums66 |
Mar 3 2013, 04:55 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Bump (IMG:style_emoticons/default/bye1.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 01:12 PM |
