Fog Lite Grounding? |
chasrolex69 |
Feb 15 2013, 04:23 PM
Newbie Group: Members Posts: 9 Joined: 19-December 12 From: rockford illinois Member No.: 15,269 Region Association: Upper MidWest |
Howdy, My fog lights quit working last night, i checked and one wire had come loose on one of them. Will that effect both lights to not work? or do they run separate?
Thanks in advance |
Mike Bellis |
Feb 15 2013, 04:28 PM
The other one should still work. You should check your fuses as the loose wire may have blown it. If you do not find a blown fuse, spin the fuses in the holder to loosen any corrosion on the fuse.
Lo-Fi Version | Time is now: 10th June 2024 - 12:50 PM |
