Transmission Shaft Seal leaking, replacing the seal |
juliomagdaleno |
Feb 19 2013, 07:37 AM
Newbie Group: Members Posts: 24 Joined: 8-January 13 From: austin Member No.: 15,350 Region Association: None |
914itis |
Feb 19 2013, 07:44 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
[/quote] You need to drain the transmission, remove the 2 bolts and pull the plate / fork out. Once out then you can use a hammer and punch tool to take out the pin. You will need to replace 2 seals in there. AA and pelican sells them. Easy job. Takes about 30 minutes once you drain the fluid. Here is a picture of the fork out |
Lo-Fi Version | Time is now: 17th June 2024 - 01:32 AM |
