Rear Swing Arm Bearing(s) |
jrrhdmust |
Feb 19 2013, 06:33 PM
Senior Member Group: Members Posts: 1,402 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. Anyway, when I look into the swing arm it looks like there are two bearings in it?
I am sand blasting the swing arm painting, then I will press out those/that bearing. I was just wondering. Thanks, John |
JFJ914 |
Feb 19 2013, 06:41 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. Anyway, when I look into the swing arm it looks like there are two bearings in it? I am sand blasting the swing arm painting, then I will press out those/that bearing. I was just wondering. Thanks, John It's a single bearing with 2 races. |
jls914 |
Feb 19 2013, 06:50 PM
Newbie Group: Members Posts: 8 Joined: 23-August 12 From: wendell, NC Member No.: 14,842 Region Association: None |
So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. Anyway, when I look into the swing arm it looks like there are two bearings in it? I am sand blasting the swing arm painting, then I will press out those/that bearing. I was just wondering. Thanks, John John, I believe that you are speaking of your rear wheel bearings. It is a single bearing with an inner and outer race. The bearings reside between the races. There are numerous articles on here and on the bird board about changing them. It can be done with the trailing arm removed from the car or with it still in place. I did mine with the arms in place. Good luck. Jim |
jrrhdmust |
Feb 20 2013, 06:21 PM
Thanks for the responses! That makes sense.
I have mine out and are rebuilding them. Thanks again! |
euro911 |
Feb 20 2013, 08:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. ... They're called 'hubs' (IMG:style_emoticons/default/shades.gif)Thanks, John |
Lo-Fi Version | Time is now: 17th June 2024 - 01:37 AM |
