So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. Anyway, when I look into the swing arm it looks like there are two bearings in it?
I am sand blasting the swing arm painting, then I will press out those/that bearing. I was just wondering.
Thanks,
John
