Rear Swing Arm Bearing(s) |
jrrhdmust |
Feb 19 2013, 06:33 PM
Senior Member Group: Members Posts: 1,402 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
So I pulled or pushed rather the outer sleave from the bearings, the part the wheel bolts too, and the drive shaft feeds through. I am sure there is a different name for it, none comes to mind right now. Anyway, when I look into the swing arm it looks like there are two bearings in it?
I am sand blasting the swing arm painting, then I will press out those/that bearing. I was just wondering. Thanks, John |
Lo-Fi Version | Time is now: 25th May 2024 - 03:38 PM |
