LED FLASHER, LED flasher help |
02loftsmoor |
Feb 20 2013, 10:16 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I work for Peterbilt, and we been have problems with Body companies using all LED lighting, this really affects the turn signals, this flasher we use for LEDs it may work on the teeners, my car is splaterd and scattered.
2FNE7 |
TheCabinetmaker |
Feb 20 2013, 01:43 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
cocktails for lunch?
904svo |
Feb 20 2013, 04:50 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
If thats a 2 prong relay it measures current to flash, you may have to put a load
resistor( 10 ohms 50 watts) to ground to simulate light bubs to work. Or check with your local auto store for a soild state flasher that will work with leds. |
02loftsmoor |
Feb 22 2013, 11:18 PM
that IS a LED flasher that's what we use
it is a two prog flasher If thats a 2 prong relay it measures current to flash, you may have to put a load resistor( 10 ohms 50 watts) to ground to simulate light bubs to work. Or check with your local auto store for a soild state flasher that will work with leds. |
Dasnowman |
Feb 23 2013, 04:33 AM
You miss 100% of shots you don't take! Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
that IS a LED flasher that's what we use it is a two prog flasher Yes but a semi has a lot more lights/LEDs running so you may still need to run a resistor? Most wiring issue's are a result of bad grounds or dirty power double check both but it seems you know what your talking about.. I had a Toyota Truck that had wiring issue's, lights always burning out, flashers working funky and I went with a ground kit with a power conditioner everyone always thought I had HID's as the head lights were super bright. The fans blew twice as fast, and better gas milage.... Thinking about it might get one for my teener.... |
02loftsmoor |
Feb 23 2013, 01:12 PM
were only using 4 lights, these are trucks were using them on not a semi.
messix |
Feb 23 2013, 01:16 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
the eletronic hd flashers that are used when towing trailers might work since they use a timer to flash and not a bimetal element to do the flashing.
02loftsmoor |
Feb 23 2013, 01:30 PM
Again these are TRUCKS not semi or traction engines, but your right this is a timer
messix |
Feb 23 2013, 01:34 PM
02loftsmoor |
Feb 23 2013, 01:35 PM
class 6,7,8
Lo-Fi Version | Time is now: 8th June 2024 - 09:38 AM |
