SVDA Distributor |
SVDA Distributor |
Jboulder |
Feb 21 2013, 06:23 PM
Newbie Group: Members Posts: 2 Joined: 4-June 11 From: Tempe, AZ Member No.: 13,154 Region Association: Rocky Mountains |
My 912E is running a 2L with dual weber 40 IDF's. Right now it's got some 009 with electronic ignition.
Would a currently available (i.e. not bosch) SVDA distributor be an upgrade? I'm looking for a reasonable mix of performance and fuel economy. Thanks in advance! (pun intended) |
KaptKaos |
Feb 21 2013, 06:24 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams!
Do your webers have a vacuum port? You will need one. |
mrbubblehead |
Feb 21 2013, 06:49 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams! Do your webers have a vacuum port? You will need one. ive got my total advance cranked up to 35 degrees max advanced now. svda distributor, and my cyl. head temps went DOWN 25 degrees. AT LEAST 25. |
KaptKaos |
Feb 21 2013, 07:33 PM
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams! Do your webers have a vacuum port? You will need one. ive got my total advance cranked up to 35 degrees max advanced now. svda distributor, and my cyl. head temps went DOWN 25 degrees. AT LEAST 25. I'd have to go through all of the mixture adjustments if I advance it, no? |
mrbubblehead |
Feb 21 2013, 09:13 PM
brant |
Feb 22 2013, 09:59 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
to the original poster.
nice to see another colorado guy on here there are a few of us around close to you. the 009 is not a very good distributor for these motors. |
72hardtop |
Nov 12 2013, 02:32 AM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams! Do your webers have a vacuum port? You will need one. ive got my total advance cranked up to 35 degrees max advanced now. svda distributor, and my cyl. head temps went DOWN 25 degrees. AT LEAST 25. This with or without the vac line attached & plugged? |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:31 PM |
