WTB: 911 rear hubs |
blitZ |
Feb 22 2013, 01:13 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Need rear hubs for 5 lug conversion.
Two 911 ('69 - '73?) hubs, must have same bearing surface width as the 914 hubs |
gcrotvik |
Feb 22 2013, 03:14 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I have a set of early (69-73) hubs with 65 MM studs and a set of early 911, 108 MM stubs. I will throw in a set of 45 MM studs if needed. I do not have the 100 MM stubs. All are in good original condition. Use them like they are or have them plated, your call. PM me with your email for pictures (I will have to get the pictures to you tomorrow morning) if interested.
$175.00 plus actual shipping for hubs & stubs (sorry, I won't break up the set). Greg Attached image(s) |
blitZ |
Feb 25 2013, 09:25 AM
B2524 |
Feb 25 2013, 12:48 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Les,
if you use 912 hubs you can reuse your 914 rotors if you want to save money and or weight. you can get 912 hubs for next to nothing. I used them and BMW calipers with 914 rotors. or you can get 911 hubs if you are going vented. just a thought. KD |
Jgilliam914 |
Feb 25 2013, 01:19 PM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
I have a nice clean pair with 50 mm wheel studs I'd let go for $125 Send me a PM and I will fwd on a photo
ArtechnikA |
Feb 25 2013, 01:53 PM
QUOTE Need hubs for 5 lug conversion. Front or back? Both ? I don't have either but the replies sound as if they're talking about two separate things. So probably be best to make sure you're all talking about the same things... |
blitZ |
Feb 25 2013, 01:57 PM
Duh, I guess that would help. I'm looking for rears.
Thanks QUOTE Need hubs for 5 lug conversion. Front or back? Both ? I don't have either but the replies sound as if they're talking about two separate things. So probably be best to make sure you're all talking about the same things... |
Jgilliam914 |
Feb 25 2013, 02:57 PM
Too bad... I have the fronts
gcrotvik |
Feb 25 2013, 03:31 PM
Picture of hubs/108 MM stubs added.
Lo-Fi Version | Time is now: 8th June 2024 - 08:56 AM |
