Do I have a 1.8 or a 2.0? |
pbob42 |
Feb 24 2013, 05:46 PM
Newbie Group: Members Posts: 46 Joined: 6-June 12 From: san diego Member No.: 14,531 Region Association: None |
Showed my '73 to a guy today and he said I have a 1.8 not a 2.0 because 2.0 plugs should come in at a 45 degree angle. I am a little confused. I buy 2.0 parts. My serial number is infront of the oil fill hole. Can you guys help me out here?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1361749570.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1361749570.2.jpg) |
Rockaria |
Feb 24 2013, 05:50 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Looks like a 1.7 actually... A 73 2.0 has a more square air filter housing, and there are only three bolts holding the intake plenum to the heads.
73 2.0 engine number: 73 2.0 air cleaner, plenum: |
jimkelly |
Feb 24 2013, 05:52 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
if you have an MPS, you have a 1.7 or 2.0
seems you have 4 nuts holding your intake runners to the heads, so that should be 1.7 if you have an mps that sn# tag is unique |
pbob42 |
Feb 24 2013, 06:09 PM
here is a shot without the air cleaner.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1361750989.1.jpg) |
Rockaria |
Feb 24 2013, 06:12 PM
It looks exactly like a 1.7 with D-Jet fuel injection.
pbob42 |
Feb 24 2013, 06:13 PM
what a crummy day. I lost 15% of my motor.
TheCabinetmaker |
Feb 24 2013, 06:15 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
A definite 1.7
billh1963 |
Feb 24 2013, 07:02 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Spark plugs are the giveaway as well....1.7
JawjaPorsche |
Feb 24 2013, 07:06 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Showed my '73 to a guy today and he said I have a 1.8 not a 2.0 because 2.0 plugs should come in at a 45 degree angle. I am a little confused. I buy 2.0 parts. My serial number is infront of the oil fill hole. Can you guys help me out here? (IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1361749570.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1361749570.2.jpg) I have a 1.7 and it looks exactly like yours. 1.7 are good engines. Porsche put them in 914's for four years. Don't be disappointed, I think you hit the jackpot! (IMG:style_emoticons/default/beerchug.gif) I would address some fuel hoses including injector hoses. Also replace clamps with proper fuel clamps. |
914Sixer |
Feb 24 2013, 07:14 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
1.7 engine numbers start with a W, EA, EB. I have never seen a number like what you are showing. 1.7, 1.8 Numbers are on a diagonal on engine block NOT at the filler neck.
442nd914s |
Feb 24 2013, 07:38 PM
Member Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
It's defintely not a 2.0. I have a '73 2.0 Djet thats looks nothing like that. And plugs are at +/- 45 degrees. Having said that, my air box is slight different. It doesn't have the "x/criss cross" pattern on the top. Its square with parallel bars. |
euro911 |
Feb 24 2013, 08:00 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
It looks like a 1.7, but until you tear it apart and look inside (to measure all the components), it's anybody's guess (IMG:style_emoticons/default/confused24.gif)
The replacement tag is from a re-manufacturing shop (like GEX) |
Tom_T |
Feb 24 2013, 08:23 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
It looks like you can see the original engine case number peeking from behind that tag attached with the rivets. My guess is that the outfit who rebuilt the motor at sometime affixed their own case/rebuild no. with the rivets. It's not a Porsche factory rebuild, cuz they'll have an "X" at the end of the no. stamped in the case for "Exchange" motor IIRC. PS - It looks like Mark was thinking the same thing while I was typing! ;-) |
76-914 |
Feb 24 2013, 08:37 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
A 1.7 will keep up w/ the 1.8's & 2.0's just fine in the twisties. And isn't that where we drive them? (IMG:style_emoticons/default/beerchug.gif)
euro911 |
Feb 24 2013, 08:38 PM
I have a 1.8L long block with a similar tag ... looks like it's from the same rebuilder
pbob42 |
Feb 25 2013, 07:20 AM
well that answers the tag - thanks guys
Lo-Fi Version | Time is now: 8th June 2024 - 01:28 PM |
