In the "For What it's Worth Catagory" |
76-914 |
Feb 24 2013, 06:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I found this hose that came with a wet vac that I bought at HD or Lowe's. Whichever one it is sells the 2 different size hoses and related accessories. I've found that those 3-5 gal wet vacs work better with the small hose so I usually shit can these larger dia hoses that come with them, by the adapter and use the 1 7/8" small hose instead. I decided to see how close this old hose was to the unobtanium OG hose and damn if it isn't tight as hell. It's an ID fit vs. an OD fit but cheap bastards don't let these things get in the way. I wouldn't use it in the engine compartment but I'll bet it's fine in this area. I'm not pursuing this as I'm going water cooled and will use this space as a conduit.
Valy |
Feb 24 2013, 06:33 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Unobtainium?!?
I got a set from Pelican Parts Las year and still have some leftovers. Drop a line if you need it. |
Mike Bellis |
Feb 24 2013, 06:40 PM
Many VW shops have the hose too.
Jeff Hail |
Feb 24 2013, 07:18 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
The only problem is you lose that Ye Old German Car Camel Hair Smell.
Pat Garvey |
Feb 24 2013, 08:19 PM
76-914 |
Feb 24 2013, 08:40 PM
Unobtainium?!? I got a set from Pelican Parts Las year and still have some leftovers. Drop a line if you need it. Thx but I won't need them. I took off some really nice paper ones. Didn't know PP sold them. Everything I had seen was A/C ducting that was a hair too big. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:24 AM |
