> rod to crank assembly
jmargush
post Feb 27 2013, 06:44 PM
I had a slight issues while assembling one of the rods to my crank.
As I got the nuts snugged up the rod was tight and didn't really rotate.
Pulled it back apart and looks like the bearing must have slipped or rotated, and the tang on the bearing crushed and actually marred up the slot on the connecting rod too.
Bearing looks like it is toast
Can you buy just 2 halves of a rod bearing or do you have to buy a whole other set?
Hopefully cleaning up the rod won't mess up the balance job too bad.
Replies(1 - 5)
wndsrfr
post Feb 27 2013, 06:50 PM
QUOTE(jmargush @ Feb 27 2013, 04:44 PM) *
Last set I bought from Summit Racing came as individual boxes of 2 bearing halves. Well, those were Chevy journal bearings...Clevites...
Mike Bellis
post Feb 27 2013, 06:51 PM
Resident Electrician
I think you have to buy a whole set unless you can exactly identify it (by size and part number) and deal with a manufacturer.
Most people do not have spares... (IMG:style_emoticons/default/sad.gif)
jmargush
post Feb 27 2013, 07:54 PM
I guess I will end up with some spares.
Valy
post Feb 27 2013, 10:35 PM
Post an add in the classifieds. Maybe someone went through the same thing.
I don't thing the rod got damaged since the bearings are soft and will give first.
Valy
post Feb 27 2013, 10:36 PM
- Lo-Fi Version Time is now: 11th July 2025 - 01:34 PM
