| tumamilhem |
Mar 2 2013, 09:54 AM
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
Please forgive my mechanical ignorance, but what exactly are "jugs" on the engine? When you put larger jugs on an engine for more power, exactly what does that mean and by how much power does it increase?
| Jgilliam914 |
Mar 2 2013, 09:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
Jugs.... Pistons and cylinders= displacement + Horsepower ..How much is determined by size of Jugs and compression for starters.
| tumamilhem |
Mar 2 2013, 10:52 AM
What would be the largest size jugs to install? Where/how can I identify them? Are they actually "jugs"? Sorry for my ignorance.
Is compression for starter different from engine compression? I think my compression is low. When I had it towed and put it in 1st gear, it still rolled backwards. |
| r_towle |
Mar 2 2013, 06:53 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| Dave_Darling |
Mar 2 2013, 07:05 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
"Jugs" is a nickname for the cylinders.
I think I have heard of 107mm cylinders at one point. The largest common size is 105mm. They're a whole lot of work to fit, and they require significant machining of the case and heads to even fit at all. Let alone work to flow enough air to adequately fill the cylinders. And work to make sure it stays together for a little while. The general consensus is if you go larger than 96mm cylinders, you either spend the big $$ for the Nikasil-plated aluminum cylinders, or you live with the idea that you'll be rebuilding very frequently. The big cast-iron cylinders don't seem to be made that well, and they don't shed heat as well as aluminum does. The cast-iron 96mm cylinders can work pretty well. With the stock 1.7 or 1.8 crank (66mm stroke), they give you 1911cc displacement. With the 2.0 crank (71mm) you get 2056cc. --DD |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:24 AM |
