> Help adding rear negative camber
sixaddict
post Mar 10 2013, 08:09 PM
Just corded another rear tire on outboard edge due to in adequate negative camber...Unable to get more than 1.8 - 1.9 ...All shims out.....
How can it be done without chopping up the car. Looking for at least 2.5
Thanks
Terry
Replies(1 - 7)
Krieger
post Mar 11 2013, 09:36 AM
I spoke to Chris at tangerine racing about this once. He sells his own trailing arm brackets that he might be able to build with a little more camber.
Woody
post Mar 11 2013, 10:43 AM
Sandbox Rabblerouser and head toilet scrubber
How low is the car?
post Mar 11 2013, 11:48 AM
Resident German
Stupid idea, but maybe a custom shim that is cut at an angle?
Thin on the outside and thick on the inside.
In theory, that should give you more negative camber ...
sixaddict
post Mar 11 2013, 12:30 PM
Thanks
Spoke to Chris this morning and first thing he said is LOWER the car....Or he should have said it in caps ...Been debating that with shop but he added some valuable info. May need to move spindles a bit to allow front to match but I am betting we are going down !
Thanks
post Mar 11 2013, 03:54 PM
Resident German
QUOTE(SirAndy @ Mar 11 2013, 10:48 AM) *
Well, after giving this some more thought, the wedge would only work if you relocated (lowered) the mounting hole on the inner suspension ear.
Still, that might be a viable option ...
(IMG:style_emoticons/default/smash.gif)
spaceshuttle
post Mar 16 2013, 09:24 PM
QUOTE(sixaddict @ Mar 11 2013, 10:30 AM) *
Thanks
Thanks
Good thing you made your splitter/air dam removeable
naro914
post Mar 19 2013, 06:07 AM
Losing my mind...
Yes, you need to lower it.
And sell the 17" and go back to 16" wheels.
- Lo-Fi Version Time is now: 15th June 2026 - 03:39 AM
